Private Const FILE_DEVICE_HAL As Integer = &H101
Private Const METHOD_BUFFERED As Integer = 0
Private Const FILE_ANY_ACCESS As Integer = 0
Private Function CTL_CODE( _
ByVal DeviceType As Integer, _
ByVal Func As Integer, _
ByVal Method As Integer, _
ByVal Access As Integer) As Integer
Return (DeviceType << 16) Or (Access << 14) Or (Func << 2) Or Method
End Function
Declare Function KernelIoControl Lib "CoreDll.dll" _
(ByVal dwIoControlCode As Integer, _
ByVal lpInBuf As IntPtr, _
ByVal nInBufSize As Integer, _
ByVal lpOutBuf As IntPtr, _
ByVal nOutBufSize As Integer, _
ByRef lpBytesReturned As Integer _
) As Integer
Private Function ResetPocketPC() As Integer
Dim bytesReturned As Integer = 0
Dim IOCTL_HAL_REBOOT As Integer = CTL_CODE(FILE_DEVICE_HAL, _
15, METHOD_BUFFERED, FILE_ANY_ACCESS)
Return KernelIoControl(IOCTL_HAL_REBOOT, IntPtr.Zero, 0, _
IntPtr.Zero, 0, bytesReturned)
End Function
Private Sub ResetDevice()
Dim msg As String
Dim title As String
Dim style As MsgBoxStyle
Dim response As MsgBoxResult
msg = "Are you sure you want to reset the device?"
style = MsgBoxStyle.DefaultButton2 Or _
MsgBoxStyle.Question Or MsgBoxStyle.YesNo
title = "Device Reset"
response = MsgBox(msg, style, title)
If response = MsgBoxResult.Yes Then ' User chose Yes.
ResetPocketPC()
End If
End Sub
