Jochen Kühner
Level-3
Hallo, Ich möchte gern aus der Oscat lib die Funktion für den Sonnenstand verwenden, doch diese liefert bei mir leider falsche Werte! Irgendwelche Tips???
(* @PATH := '\/Time&Date' *)
FUNCTION_BLOCK sun_pos
TITLE = 'sun_pos'
// version 1.0 22.feb 2008
// programmer jochen
// tested by
// this FUNCTION block calculates the sun position for a given date and time.
// the times are calculated in utc and have to be corrected for the given time zone.
// B is the angle from north and HR is the highth in degrees.
// uses: oscat/mathematical/modR
// oscat/mathematical/deg
// oscat/mathematical/Rad
VERSION : '1.0'
AUTHOR : jochen
FAMILY : TIDT
VAR_INPUT
year : INT;
month : INT;
day : INT;
hour : INT;
minute : INT;
second : INT;
latitude : REAL; (* latitude of geographical position *)
longitude : REAL; (* longitude of geographical position *)
END_VAR
VAR_OUTPUT
azimuth : REAL;
height : REAL;
END_VAR
VAR
DAYOFYEAR:
ARRAY[0..11] OF INT:= 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334;
END_VAR
VAR_TEMP
J: REAL;
J2: REAL;
Zgl: REAL;
MOZ: REAL;
WOZ: REAL;
w: REAL;
decl: REAL;
sunaz: REAL;
sunhi: REAL;
asinGs: REAL;
acosAs: REAL;
END_VAR
BEGIN
(* EXIT the routine IF it was executed the 10 seconds which is equal to 0.04 degrees accuracy *)
// IF DWORD_TO_DINT(T_PLC_MS()) - DWORD_TO_DINT(last) < 10000 THEN RETURN; END_IF;
// last := T_PLC_MS();
J2 := 365.0;
IF modR(IN:=year, DIVI:=4.0) = 0.0 THEN J2 := J2 + 1.0; END_IF;
J := DAYOFYEAR[month-1] + day;
IF modR(IN:=year, DIVI:=4.0) = 0.0 AND (modR(IN:=year, DIVI:=100.0) <> 0.0 OR modR(IN:=year, DIVI:=400.0) = 0.0) AND month > 2 THEN J := J + 1.0; END_IF;
MOZ := hour + (1.0/60.0) * minute + (1.0/360.0) * second + 1.0;
MOZ := MOZ - 4.0 * (15.0 - longitude) / 60.0;
J := J * 360 / J2 + MOZ / 24;
decl := 0.3948 - 23.2559 * COS(Rad(J + 9.1)) - 0.3915 * COS(RAD(2.0 * J + 5.4)) - 0.1764 * COS(Rad(3.0 * J + 26.0));
Zgl := 0.0066 + 7.3525 * COS(rad(J + 85.9)) + 9.9359 * COS(rad(2.0 * J + 108.9)) + 0.3387 * COS(rad(3.0 * J + 105.2));
WOZ := MOZ + Zgl / 60.0;
w := (12.0 - WOZ) * 15.0;
asinGs := COS(rad(w)) * COS(rad(latitude)) * COS(rad(decl)) + SIN(rad(latitude)) * SIN(rad(decl));
IF asinGs > 1 THEN asinGs := 1; END_IF;
IF asinGs < -1 THEN asinGs := -1; END_IF;
sunhi := deg(ASIN(asinGs));
acosAs := (SIN(rad(sunhi)) * SIN(rad(latitude)) - SIN(rad(decl))) / (COS(rad(sunhi)) * COS(rad(latitude)));
IF acosAs > 1 THEN acosAs := 1; END_IF;
IF acosAs < -1 THEN acosAs := -1; END_IF;
sunaz := deg(ACOS(acosAs));
IF ((WOZ > 12) OR (WOZ < 0)) THEN sunaz := 180 + sunaz; ELSE sunaz := 180 - sunaz; END_IF;
azimuth := sunaz; //ROUND(sunaz*1000)/1000;
height := sunhi; //ROUND(sunhi*1000)/1000;
END_FUNCTION_BLOCK
