Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Archivierung mit einer S7 200
    don_g is offline Neuer Benutzer
    Join Date
    Hallo vladi
    kannst du mir die komunikation mit der rs232 schnitstelle mal erklären?
    mfg don g
    Join Date
    guckst du hier:
    Und in die S7 200 Handbücher..
    Creating User-Defined Protocols with Freeport Mode
    Freeport mode allows your program to control the communications port of the S7-200 CPU. You
    can use Freeport mode to implement user-defined communications protocols to communicate with
    many types of intelligent devices. Freeport mode supports both ASCII and binary protocols.
    To enable Freeport mode, you use special memory bytes SMB30 (for Port 0) and SMB130 (for
    Port 1). Your program uses the following to control the operation of the communications port:
    Transmit instruction (XMT) and the transmit interrupt: The Transmit instruction allows the
    S7-200 to transmit up to 255 characters from the COM port. The transmit interrupt notifies
    your program in the S7-200 when the transmission has been completed.
    Receive character interrupt: The receive character interrupt notifies the user program that a
    character has been received on the COM port. Your program can then act on that character,
    based on the protocol being implemented.
    Receive instruction (RCV): The Receive instruction receives the entire message from the
    COM port and then generates an interrupt for your program when the message has been
    completely received. You use the SM memory of the S7-200 to configure the Receive
    instruction for starting and stopping the receiving of messages, based on defined
    conditions. The Receive instruction allows your program to start or stop a message based
    on specific characters or time intervals. Most protocols can be implemented with the
    Receive instruction.
    Freeport mode is active only when the S7-200 is in RUN mode. Setting the S7-200 to STOP mode
    halts all Freeport communications, and the communications port then reverts to the PPI protocol
    with the settings which were configured in the system block of the S7-200.
    Gruss: Vladi
    relax, take it easy
    Reply With Quote Reply With Quote S7 200 + Rs232
Similar Threads
  1. Archivierung auf MMC Karte
    By Hotsch in forum HMI
    Last Post: 12.11.2009, 08:54
  2. Archivierung von Variablen
    By Karli in forum Simatic
    Last Post: 18.06.2008, 11:45
  3. Archivierung von Meldungen
    By digga in forum HMI
    Last Post: 15.03.2008, 08:50
  4. Fehler bei Archivierung
    By duMMbatz in forum Simatic
    Last Post: 27.11.2007, 11:48
  5. Tag Logging + Archivierung
    By mrdanger in forum HMI
    Last Post: 29.01.2007, 10:47
Posting Permissions
  • You may not post replies
  • You may not edit your posts
