Hello,
I have to realize the control of an hydraulic swingshear using two coupled hydraulic cylinders as shown in the figure below.
The old control is realized with the CFC
Everything stays the same only the control changes. Positioning from +45 to -45 should be done in 1 second.
Since the conversion of CFC into another language available in 1500 is not possible, control should be done new.
Would sinamics s 120 hydraulic drive be useful for this application?
Any suggestion on how to realize Pressure/ positon / velocity and flow control ??
(Continuous Function Chart)
using the old module T400 masterdrive, and now the new control has to be done in the new series 1500.Everything stays the same only the control changes. Positioning from +45 to -45 should be done in 1 second.
