Tabo260897
Hello. I am building a cable to connect beckhoff terminal EL6022 and a Piezo PMD301 motion controller. The connector from EL6022 is a 9Pin Dsub Male. The side of Piezo motion controller is Stereo Jack 3.5 mm TRS cable. The communication set between them is RS485 .
The data sheet of Piezmotor says :
RS485
TRS Function I/O Notes
Tip Data+ In/Out Idle high; 47k to 5V
Ring Data− In/Out Idle low; 23k to 2.5V
Sleeve GND485 GND485 100Ω to GND
For implementing EMC surge protection, refer to Texas Instrumentsdatasheet SN65HVD82. Use standard 3.5 mm stereo plug (TRS).
So i connected TX+ and RX+ in a bridge with the tip and TX- and RX- with Ring and ground with sleeve.
But i could not achieve the communication. Than i saw the Notes but i dont understand them fully.
Should i connect a 47 kOhm resistance at 5 V and than connect it to where (tip or ring ) and 100 Ohm to ground ? I am confused.
I would be grateful to help me to solve this problem.
RS485
