Ergebnis 1 bis 3 von 3
Thema: WINCC Flexible simple message view
    27.03.2007
    I'm very sorry but i don't speak much german. I can read it more or less because a lot of documentation is in the german language. I hope you all do not have a problem if I post a question in english. Well..
    .. I'm using wincc flexible 2005 and a simple message view. The message view displays 6 rows, configured as pending alarms. The last incoming event is always displayed selected. Is it possible to prevent this selection. In "the good old" protool I do not have this problem, if I switched off the tab order for the message view object. I really hope that some of you have a solution.
    With best regards
    Zitieren Zitieren WINCC Flexible simple message view
    06.10.2004
    Kopenhagen.
    377
    I think that in Protool you also would get the message view selected.
    You can set the tab order so that the message view becomes the last on the screen.
    How can you "switch off the tab order" ?
    Jesper M. Pedersen
    AFJ_NL ist offline Neuer Benutzer
    27.03.2007
    In protool, select tab order from the menu. Then right click on the object and choose "Tab order off". With this settings you also get a selection on the message view but only a very thin rectangle.
  1. Antworten: 3
  2. Simple Fragen
    Von Anno74 im Forum Feldbusse
    Letzter Beitrag: 20.11.2006, 20:22
  3. simple C-Aktion in WinCC
    Von Spanier im Forum HMI
    Letzter Beitrag: 12.10.2006, 03:28
  4. Simple Schaltung in S5
    Von PatrickR im Forum Simatic
    Antworten: 13
    Letzter Beitrag: 31.03.2006, 14:46
  5. Problem mit WinCC V6.0 und Message Queuing
    Von apachler im Forum HMI
    Letzter Beitrag: 23.03.2006, 14:59
