Ergebnis 1 bis 2 von 2
Thema: VBA - Wie funktioniert das in VBS - Win CC?!
    Anonymous Gast
    habe follgendes programm in vba(excel) müsste das in wincc zum laufen bringen...
    Sub test()
    Dim Dateiname As String
    Dim strtmp As String
    Dim HEUTE As Date
    Dim Jetzt As Date
    Dim Eintrag As String
    Dim BTAKKZ, BTFAUN, BTXUNT, BTAPNR, BTIDNR, BTMEKZ As String
    Dim BTYUNV, BTYUNB, BTYSTT, BTYENT As String ' Datum
    Dim BTUNZV, BTUNZB, BTSZTT, BTEZTT As String ' Uhrzeit
    Dim BTPONR As Integer
    Dim BTVBME As Currency
    Dim Auftragsnummer, Teilenummer As String ' WinCC Variable
    Dim Chargennummer As Integer ' WinCC Variable
    Dim Verbrauchsmenge As Currency ' WinCC Variable evt auch single
    Dim Einheit As String 'WinCC Variable max 2Zeichen
    HEUTE = Date
    Jetzt = Time
    'Vorläufige Parameterversorgung statt WinCC Variable
    Auftragsnummer = "BUE0815"
    Teilenummer = "4711FH" 'von Masterplatte
    Chargennummer = 1
    Verbrauchsmenge = 222.33
    Einheit = "kg"
    Dateiname = "c:\AccessÜbungen\G10_" & Format(HEUTE, "ddmmyyyy") & ".csv"
    MsgBox Dateiname
    ' Snapshot bei Charge Start
    BTAKKZ = "AS"
    BTFAUN = Auftragsnummer
    BTXUNT = ""
    BTYUNV = "" 'Format(HEUTE, "dd.mm.yyyy")
    BTUNZV = "" 'Format(Jetzt, "hh:mm:ss")
    BTYUNB = "" 'Format(HEUTE, "dd.mm.yyyy")
    BTUNZB = "" 'Format(Jetzt, "hh:mm:ss")
    BTAPNR = "G10"
    BTPONR = Chargennummer
    BTYSTT = Format(HEUTE, "dd.mm.yyyy")
    BTSZTT = Format(Jetzt, "hh:mm:ss")
    BTYENT = "" 'Format(HEUTE, "dd.mm.yyyy")
    BTEZTT = "" 'Format(Jetzt, "hh:mm:ss")
    BTIDNR = Teilenummer
    BTVBME = Verbrauchsmenge
    BTMEKZ = Einheit
    Eintrag = BTAKKZ & "," & BTFAUN & "," & BTXUNT & "," & BTYUNV & "," & BTUNZV & "," & BTYUNB & "," & BTUNZB & "," & BTAPNR & "," & BTPONR & "," & BTYSTT & "," & BTSZTT & "," & BTYENT & "," & BTEZTT & "," & BTIDNR & "," & BTVBME & "," & BTMEKZ
    Open Dateiname For Append As #1
    Print #1, Eintrag
    ' Sollwerte aus WinCC TRM_Anteil, TRM_Massenstrom, TRM1, MTRM1..4, TRADD1, MTADD1..4, NAM,Dichte, Niveau , Solltemperatur, NAADD1, NAADD2,MNAM, MNAADD1, MNAADD2
    Close #1
    End Sub
    nun das problem, win cc kennt weder den befehl dim ... as string (anweisungsende erforderlich?!) noch die open funktion...kann da jmd helfen?!
    Zitieren Zitieren Gelöst: VBA - Wie funktioniert das in VBS - Win CC?!
  2. "vbscript ist es völlig egal ob eine variable eine zahl oder ein string ist.
    also einfach so: DIM Dateiname
    eine datei zum beschreiben öffnest du so:
    Set MyFiles = CreateObject("Scripting.FileSystemObject")
    Set TextFile1 = MyFiles.CreateTextFile(Dateiname[, Überschreiben[, Unicode]])
    bzw so
    Set TextFile1 = MyFiles.OpenTextFile(Dateiname[, E/A-Modus[, Erstellen[, Format]]])
    modus=1=lesen, modus=8=anhängen
    google mal nach "VBScript-Sprachverzeichnis""
  3. #2
    20.06.2003
    Sauerland.NRW.Deutschland
    78
    bzw so
  1. Wie funktioniert ein Kaltwassersatz?
    Von veritas im Forum Stammtisch
    Letzter Beitrag: 13.07.2014, 10:09
  2. MID-FC in SCL funktioniert nicht
    Von nobby_nobbs im Forum Simatic
    Letzter Beitrag: 19.03.2009, 02:14
  3. MMC funktioniert nicht
    Von MesSen-Nord im Forum Simatic
    Letzter Beitrag: 23.10.2008, 11:06
  4. Wie funktioniert PLCSIM?
    Von Drain im Forum Simatic
    Letzter Beitrag: 17.07.2008, 13:18
  5. Wie funktioniert das mit TD 200?
    Von maxi im Forum Simatic
    Letzter Beitrag: 05.07.2006, 16:02
