Ergebnis 1 bis 10 von 13
Thema: Pumpenpendelung
    TedescoA Gast
    Rotes Gesicht
    Ich habe Pumpenpendelung in SCL für 3 Pumpen geschrieben,
    ich möchte es auf 6 Pumpen ausbauen, leider habe ich die Übersicht verloren kann mir jemanden helfen?
    Ihr ist der Code für 3 Pumpen:
    VAR_INPUT
    QUARTZ_Sec,QUARTZ_Min,READY1,READY2,READY3: BOOL;
    END_VAR
    VAR_OUTPUT
    RUN1, RUN2, RUN3: bool;
    END_VAR
    VAR_IN_OUT
    REQUESTED, TurnOverPresetTime, TurnOverRemainTime, OverlapPresetTime, OverlapRemainTime, SEQ : INT;
    END_VAR
    VAR_TEMP
    AccountToReady, AccountToRun, xSeq, xReady, xRequest : INT;
    READY : ARRAY[1..4] OF BOOL;
    Run : array[1..3] of bool;
    END_VAR
    BEGIN
    //Initialise variable
    AccountToRun := 0;
    AccountToReady := 0;
    xSeq := 1;
    xReady := 1;
    xRequest := 1;
    READY[1] := READY1;
    READY[2] := READY2;
    READY[3] := READY3;
    READY[4] := READY1;
    Run[1] := false;
    Run[2] := false;
    Run[3] := false;
    // Account ready inputs
    WHILE xReady <= 3 DO
    IF READY[xReady] = true THEN AccountToReady := AccountToReady + 1; END_IF;
    xReady := xReady + 1;
    END_WHILE;
    xReady := 1;
    //Initialing of turn over, overlap time and sequence
    IF TurnOverRemainTime <= 0 AND OverlapRemainTime <= 0 THEN
    TurnOverRemainTime := TurnOverPresetTime;
    OverlapRemainTime := OverlapPresetTime;
    SEQ:= SEQ + 1;
    END_IF;
    IF SEQ < 1 OR SEQ > 3 THEN SEQ := 1; END_IF;
    // Overlap request
    IF TurnOverRemainTime <= 0 AND OverlapRemainTime > 0 THEN Requested:= Requested + 1; END_IF;
    // Change sequence always when first of sequence isn't ready
    xReady := 1;
    IF READY[xReady] = false
    AND SEQ = xReady
    THEN
    SEQ := xReady + 1;
    TurnOverRemainTime := TurnOverPresetTime - 1;
    IF SEQ > 3 THEN SEQ := 1; END_IF;
    END_IF;
    END_WHILE;
    // Change sequence always when second of sequence isn't ready
    xReady := 1;
    IF READY[xReady+1] = false
    AND SEQ = xReady
    THEN
    SEQ := SEQ - 3 + 2;
    IF SEQ <=0 THEN SEQ := 3; END_IF;
    END_IF;
    END_WHILE;
    //Algorithme
    WHILE xSeq <= 3 DO
    IF SEQ=xSeq THEN xReady :=xSeq;
    WHILE xRequest <= 3 DO
    IF Requested = xRequest THEN
    IF READY[xReady] THEN Run[xReady]:= true;
    AccountToRun := AccountToRun + 1;END_IF;
    IF Requested = AccountToRun THEN xReady := 9999;
    ELSE xReady := xReady + 1;
    END_IF;
    IF xReady > 3 AND xReady <> 9999 THEN xReady := 1;END_IF;
    IF xReady = xSeq THEN xReady := 9999; END_IF;
    END_WHILE;
    END_IF;
    xRequest := xRequest + 1;
    END_WHILE;
    END_IF;
    xSeq := xSeq + 1;
    END_WHILE;
    //Discount turn over and overlap time
    IF AccountToReady > AccountToRun THEN
    IF QUARTZ_Min = true AND TurnOverRemainTime > 0 AND AccountToRun > 0 AND REQUESTED > 0
    THEN TurnOverRemainTime := TurnOverRemainTime - 1; END_IF;
    END_IF;
    IF QUARTZ_Sec = true AND OverlapRemainTime > 0 AND TurnOverRemainTime <= 0
    THEN OverlapRemainTime := OverlapRemainTime - 1; END_IF;
    //Ajustement of variable
    Run1:= Run[1];
    Run2:= Run[2];
    Run3:= Run[3];
    END_FUNCTION
    Zitieren Zitieren Gelöst: Pumpenpendelung
  2. "@vladi
    wenn du zugibst, dass du es nicht geschrieben hast, und dich
    bei @UG entschuldigst, hilft er dir bestimmt.
    Vladi
    Das war hoffentlich nicht ernst gemeint!
    Ich würde den Satz anders interpretieren, wär schön wenn TedescoA das klargestellt hätte, aber er scheint ja nicht zu wissen, daß das schief ankommt.
    Ich habe hier eine Punmpendeckelung, die ist in SCL geschrieben. So kann man das auch lesen und nun fürft ohr ihm helfen oder evtl. auch mal nichts mehr posten.
    @TedescoA
    Probiere das mal. Hab es allerdings auch nur stur umgesetzt, sich damit genauer zu befassen, dauert schon seine Zeit.
    FUNCTION FC200 : INT
    VAR_INPUT
    QUARTZ_Sec,QUARTZ_Min,READY1,READY2,READY3,READY4,READY5,READY6: BOOL;
    END_VAR
    VAR_OUTPUT
    RUN1, RUN2, RUN3,RUN4, RUN5, RUN6: BOOL;
    END_VAR
    VAR_IN_OUT
    END_VAR
    VAR_TEMP
    READY : ARRAY[1..7] OF BOOL;
    Run : array[1..6] of bool;
    END_VAR
    BEGIN
    AccountToRun := 0;
    xSeq := 1;
    xReady := 1;
    xRequest := 1;
    READY[1] := READY1;
    READY[2] := READY2;
    READY[3] := READY3;
    READY[4] := READY4;
    READY[5] := READY5;
    READY[6] := READY6;
    READY[7] := READY1;
    Run[1] := false;
    Run[2] := false;
    Run[3] := false;
    Run[4] := false;
    Run[5] := false;
    Run[6] := false;
    WHILE xReady <= 6 DO
    END_WHILE;
    xReady := 1;
    SEQ:= SEQ + 1;
    END_IF;
    IF SEQ < 1 OR SEQ > 6 THEN SEQ := 1; END_IF;
    // Overlap request
    xReady := 1;
    AND SEQ = xReady
    THEN
    SEQ := xReady + 1;
    IF SEQ > 6 THEN SEQ := 1; END_IF;
    END_IF;
    END_WHILE;
    xReady := 1;
    AND SEQ = xReady
    THEN
    SEQ := SEQ - 3 + 2; //was soll das eigentlich??? versuch mal SEQ := SEQ - 1;
    IF SEQ <=0 THEN SEQ := 6; END_IF;
    END_IF;
    END_WHILE;
    //Algorithme
    WHILE xSeq <= 6 DO
    WHILE xRequest <= 6 DO
    END_IF;
    IF xReady > 6 AND xReady <> 9999 THEN xReady := 1;END_IF;
    END_WHILE;
    END_IF;
    END_WHILE;
    END_IF;
    xSeq := xSeq + 1;
    END_WHILE;
    END_IF;
    Run1:= Run[1];
    Run2:= Run[2];
    Run3:= Run[3];
    Run3:= Run[4];
    Run3:= Run[5];
    Run3:= Run[6];
    FC200 := 1;
    END_FUNCTION
  3. #2
    22.09.2006
    Bodenseeraum
    61
    Beitrag
    selber geschrieben und Übersicht verloren.... .
    Na ja, die In/Outputs sollen statt 3 dann 6 werden(READY,Run usw.).
    Die Arrays genauso erweitern, auf 6 Plätze, und die Programmschleifen
    anstatt bis 3: bis 6 machen.
    Gruss: V.
    relax, take it easy
    Zitieren Zitieren Scl
    22.11.2005
    kl.Odenwald
    111
    Erhielt 85 Danke für 71 Beiträge
    Was bitte ist eine Pumpenpendelung ?
    22.09.2006
    Bodenseeraum
    61
    Beitrag
    steht doch im SCL Code ganz klar .
    (Ich würde sagen, die Pumpen wechseln sich ab, nach bestimmter Zeit).
    Gruss: V.
    relax, take it easy
    Zitieren Zitieren Wie was das ist?
  6. #5
    28.06.2006
    Königreich Neuseeland
    133
    Wenn das wahr wäre, könnte dir eh niemand mehr helfen !
  7. #6
    TedescoA Gast
    Lächeln
    Kann mir jemand die Programmschleife entsprechend anpassen
    damit Sie richtig funktioniert?
    Merci!!!
    Zitieren Zitieren Pumpenpendelung
  8. #7
    28.06.2006
    133
    Merci!!!
    Wegen deine blöden Spruch
    will ich mal hoffen, das dir hier keiner deine Arbeit abnimmt, du Großmaul !
  9. #8
    TedescoA Gast
    Ich habe es schon versucht es anzupassen, aber funktionierte nicht so richtig darum frage an, dass mir jemanden hilft, dieses Problem 100% zu lösen. Es ist nicht wegen der Faulheit das ich nachfrage.
    Ich muss diesen Code diese Woche fertig machen.
    HILFE!!!!
  10. #9
    22.09.2006
    Bodenseeraum
    61
    Beitrag
    Vladi
    relax, take it easy
    Zitieren Zitieren SCL anpassen
  11. #10
    TedescoA Gast
    Ich habe es geschrieben aber mit mithilfe von einen anderen SPS Programmierer. Ich entschuldige mich bei @UG.
