Results 1 to 8 of 8
Thread: Libnodave open a connection - S7 200 (PPI) - VB
    Join Date
    11.03.2008
    Posts
    35
    Default
    Hallo, ich schaffe es nicht in VB mit libdonave eine Verbidung zu meiner S7 CPU 224 (PPI Verbindung) zu öffnen. Als Basis habe ich das Progr. SimpleMPI aus dem Ordner dot.net / VB in Libnodave verwendet. Das geänderte Programm sieht wie folgt aus:
    Class test
            Public Shared Function Main(ByVal args() As String) As Integer
            Dim localPPI As Integer = 0, plcPPI As Integer = 2
                Dim fds As libnodave.daveOSserialType
                Dim di As libnodave.daveInterface
                Dim dc As libnodave.daveConnection
                Dim res As Integer
                Dim a, b, c As Integer, d As Single
                Dim buf(1000) As Byte
            Dim s As String
            MsgBox("Hello World!")
            fds.rfd = libnodave.setPort(args(0), "9600", AscW("0"))  ' step 1, open a connection
                fds.wfd = fds.rfd
                If fds.rfd > 0 Then       ' if step 1 is ok
                di = New libnodave.daveInterface(fds, "My Interface 1", localPPI, libnodave.daveProtoPPI, libnodave.daveSpeed187k)
                    di.setTimeout(1000000)  ' Make this longer if you have a very long response time
                    res = di.initAdapter
                    If res = 0 Then       ' init Adapter is ok
                    dc = New libnodave.daveConnection(di, plcPPI, 0, 0)  ' rack amd slot don't matter in case of MPI
                        res = dc.connectPLC()
                        If res = 0 Then
                            res = dc.readBytes(libnodave.daveFlags, 0, 0, 16, buf)
                            If res = 0 Then
                                a = dc.getS32
                                b = dc.getS32
                                c = dc.getS32
                                d = dc.getFloat
                            MsgBox("FD0:  {0:d}", a)
                            MsgBox("FD4:  {0:d}", b)
                            MsgBox("FD8:  {0:d}", c)
                            MsgBox("FD12: {0:f}", d)
                            Else
                            MsgBox("Error {0:d}={1:s} in readBytes.", res, libnodave.daveStrerror(res))
                            End If
                            dc.disconnectPLC()
                        Else
                        MsgBox("Error {0:d}={1:s} in connectPLC.", res, libnodave.daveStrerror(res))
                        End If
                        di.disconnectAdapter()  ' End connection to adapter
                    Else
                    MsgBox("Error {0:d}={1:s} in initAdapter.", res, libnodave.daveStrerror(res))
                    End If
                    libnodave.closePort(fds.rfd)    ' Clean up
                Else
                MsgBox("Couldn't open serial port {0:s}", args(0))
                    Return -1
                End If 'fds.rfd >0
            End Function 'Main
        End Class
    ... wobei für mich momentan lediglich die Zeilen
    .... und ....
    von Bedeutung sind. So stellt sich beispielsweise die Frage wie rufe ich die Public Shared Function über einen Button (Start) richtig auf?
    Mit ...
    Private Sub cmdStart_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdStart.Click
    Dim a As Integer
    Dim b(1) As String
    a = test.Main(b)
    End Sub
    ...lässt sich die Funktion zwar aufrufen, liefert aber nicht das gewünschte Ergebniss, sprich eine Verbindung und das wahrscheinlich zu Recht. Welche Werte muss ich der Funktion beim Aufruf mit auf den Weg geben ?
    Vielen Dank im Voraus,
    Lan
    Reply With Quote Reply With Quote Libnodave open a connection - S7 200 (PPI) - VB
    Join Date
    22.06.2003
    Posts
    244
    9
    Default
    Hallo, ich schaffe es nicht in VB mit libdonave eine Verbidung zu meiner S7 CPU 224 ....
    ....Als Basis habe ich das Progr. SimpleMPI
    Ich gehe davon aus Du hast ein einfaches PPI-Kabel/Adapter zur CPU224
    und nimmst aber simple_MPI ?(was für die 300/400 gedacht ist). Du musst das das PPI_test (simplePPI wenns sowas gibt als Grundlage nehmen.
    Dann gehts. PPI und MPI sind etwas unterschiedlich, und zumindest ohne den MPI-Adapter dazwischen (damit gibts einen Aufbau wo das evtl. geht) gibts da keine Connection.
    ... mit der dot.net DLL ist ja witzig ... werd ich in Delphi mal probieren vielleicht gehts denn in D2005 ja
    Gruss
    tobias
    Join Date
    11.03.2008
    Posts
    35
    Default
    Hallo Tobias, ja ich weis MPI und PPI sind 2 unterschiedliche Dinge. Für VB + PPI gibt es leider keine Vorlage, die grundsätzliche Struktur des Programmes sollte aber sehr ähnlich sein. Ich habe nun versucht die MPI Vorlage auf PPI umzubauen, zumal die testppi ja problemlos läuft und mich dazu ermutigt hat auf der Schiene weiterzuarbeiten.
    Join Date
    22.06.2003
    Posts
    244
    9
    Default
    das 'Protokoll' bei MPI und PPI ist (zumindest da wo es die in 200 & 3-400 selben Bereiche tangiert) auch nicht gross unterschiedlich, nur den 'testMPI's ist die jeweilige Adapterinitiation vorgeschaltet.
    Aber die scheint bei dir ja schon weggekürzt zu sein, jedenfalls was ich eben so sah.
    Wenn Du am ComPort die Ausgangsbytes 'abliest' muss das bei PPI irgendwie immer mit 0x68, 2 x Lämngenbytes, 0x68, ... losgehen (war glaube ich so und wird ja bei testPPI.exe -d denn auch vollständig angezeigt) bei MPI gehts da irgendwie (je nach Adaptertype) mit 0x25 los, ... - da legt die CPU dann auf und bricht die Verbindung ab.
    Gut - wenns das nicht ist stimmt die PPI-adr. ? Das wird ja (neuerdings) irgendwo mit übergeben oder ist default '2'
    Ich weiss aber von VB kaum noch was, letzte Versuche waren in Visual Studio 6 annodunnemals.
    Original siehts in 'c' ja so aus:
    fds.rfd=setPort(argv[adrPos],"9600",'E');
    fds.wfd=fds.rfd;
    if (fds.rfd>0) {
    di =daveNewInterface(fds, "IF1", localPPI, daveProtoPPI, daveSpeed187k);
    dc =daveNewConnection(di, plcPPI, 0, 0);
    daveConnectPLC(dc);
    Dein:
    machts vielleicht ja richtig, aber bei dem 'AscW("0")' kann ich nicht beurteilen worauf das 'abzielt' -- nicht das das die PPIadr. oder 'E' als Parität plattbügelt
    War nur so ein Unterschied der mir eben visuell auffiel, ich nehme zumeist die Vorgängerversionen, da war das alles im Quelltext 'fixiert' und übergebe die Parameter seltener über die Kommandozeile. Da muss ich denn auch jedesmal probieren wodrauf das noch gerichtet war
    Gruss
    tobias
    Join Date
    11.03.2008
    Posts
    35
    Default
    Hallo Tobias, ja das war sozusagen meine zweite Vorlage
     Very simple program to read from a 200 PLC via PPI cable.
     This shall provide users with a simple starting point for their own
     applications.
     Part of Libnodave, a free communication libray for Siemens S7 200/300/400
     (C) Thomas Hergenhahn (thomas.hergenhahn@web.de) 2005
     Libnodave is free software; you can redistribute it and/or modify
     it under the terms of the GNU Library General Public License as published by
     the Free Software Foundation; either version 2, or (at your option)
     any later version.
     Libnodave is distributed in the hope that it will be useful,
     but WITHOUT ANY WARRANTY; without even the implied warranty of
     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
     GNU General Public License for more details.
     You should have received a copy of the GNU Library General Public License
     along with Libnodave; see the file COPYING.  If not, write to
     the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
    using System;
    class test {
        static libnodave.daveOSserialType fds;
        static libnodave.daveInterface di;
        static libnodave.daveConnection dc;
        static int localPPI=0;
        static int plcPPI=2;
        public static int Main (string[] args)
        int i,a=0,j,res,b=0,c=0;
        float d=0;
            fds.rfd=libnodave.setPort(args[0],"9600",'E');
        fds.wfd=fds.rfd;
            if (fds.rfd>0) {
            di =new libnodave.daveInterface(fds, "IF1", localPPI, libnodave.daveProtoPPI, libnodave.daveSpeed187k);
                di.setTimeout(1000000);
    //        res=di.initAdapter();    // does nothing in PPI. But call it to keep your programs indpendent of protocols
    //        if(res==0) {
            dc = new libnodave.daveConnection(di,plcPPI, 0, 0);
            if (0==dc.connectPLC()) {
                res=dc.readBytes(libnodave.daveFlags, 0, 0, 16, null);
                if (res==0) {
                    a=dc.getS32();
                    b=dc.getS32();
                    c=dc.getS32();
                d=dc.getFloat();
                Console.WriteLine("FD0: " + a);
                Console.WriteLine("FD4: " + b);
                Console.WriteLine("FD8: " + c);
                Console.WriteLine("FD12: " + d);
                } else
                Console.WriteLine("error "+res+" "+libnodave.daveStrerror(res));
            dc.disconnectPLC();
    //        di.disconnectAdapter();    // does nothing in PPI. But call it to keep your programs indpendent of protocols
            libnodave.closePort(fds.rfd);
        } else {
            Console.WriteLine("Couldn't open serial port "+args[0]);
            return -1;
        return 0;
    Ich habe also als Vorlage einen C# Code für PPI und einen VB Code für MPI, meine Aufgabe ist es nun daraus einen VB code für PPI zu erstellen.
    Join Date
    11.03.2008
    Posts
    35
    Default
    Hier noch die Vorlage VB / MPI
    ' Very simple program to read from a 300/400 PLC via MPI adapter.
    ' This shall provide users wit a simple starting point for their own
    ' applications.
    ' Part of Libnodave, a free communication libray for Siemens S7 200/300/400
    ' (C) Thomas Hergenhahn (thomas.hergenhahn@web.de) 2005
    ' Libnodave is free software; you can redistribute it and/or modify
    ' it under the terms of the GNU Library General Public License as published by
    ' the Free Software Foundation; either version 2, or (at your option)
    ' any later version.
    ' Libnodave is distributed in the hope that it will be useful,
    ' but WITHOUT ANY WARRANTY; without even the implied warranty of
    ' MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    ' GNU General Public License for more details.
    ' You should have received a copy of the GNU Library General Public License
    ' along with Libnodave; see the file COPYING.  If not, write to
    ' the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
    Imports System
    Imports Microsoft.VisualBasic
    Class test
        Public Shared Function Main(args() As String) As Integer
        Dim localMPI As Integer = 0, plcMPI As Integer = 2
        Dim di as libnodave.daveInterface
        Dim dc as libnodave.daveConnection
        Dim res As Integer
        Dim a,b,c As Integer, d As Single
        Dim buf(1000) as byte
        Dim s As string
        Console.WriteLine("Hello World!")
            fds.rfd=libnodave.setPort(args(0), "38400", AscW("O"))    ' step 1, open a connection
        fds.wfd=fds.rfd
            if fds.rfd>0 then        ' if step 1 is ok
            di =new libnodave.daveInterface(fds, "My Interface 1", localMPI, libnodave.daveProtoMPI, libnodave.daveSpeed187k)
            if res=0 then        ' init Adapter is ok
            dc = new libnodave.daveConnection(di, plcMPI, 0, 0)  ' rack amd slot don't matter in case of MPI
            res=dc.connectPLC()
            if res=0 then
                res=dc.readBytes(libnodave.daveFlags, 0, 0, 16, buf)
                if res=0 then
                    a=dc.getS32
                    b=dc.getS32
                    c=dc.getS32
                d=dc.getFloat
                Console.WriteLine("FD0:  {0:d}", a)
                Console.WriteLine("FD4:  {0:d}", b)
                Console.WriteLine("FD8:  {0:d}", c)
                Console.WriteLine("FD12: {0:f}", d)
                else
                Console.WriteLine("Error {0:d}={1:s} in readBytes.", res, libnodave.daveStrerror(res))
                end if
                dc.disconnectPLC()
            else
                Console.WriteLine("Error {0:d}={1:s} in connectPLC.", res, libnodave.daveStrerror(res))
            end if
            else
            Console.WriteLine("Error {0:d}={1:s} in initAdapter.", res, libnodave.daveStrerror(res))
            end if
        else
            Console.WriteLine("Couldn't open serial port {0:s}", args(0))
            return -1
        end if 'fds.rfd >0
        end Function 'Main
    END class
    Der Code eingangs ist mein Versuch das Ganze auf PPI umzubauen
    Join Date
    22.06.2003
    Posts
    244
    9
    Default
    der meine ich ist richtig - oder sprich: Stimmt mit dem überein was ich benutze.
    Die Parität müsste 'E' ==even sein, die Baudrate ja wie eingestellt.
    'Ein Vordruck weiter' ist die Parity allerdings auf 'O' (odd) umgemünzt. (Ich hatte letztesmal noch '0==Null' gelesen. 'AscW("O")' wird dann aber die Parität in odd überschreiben und da steht die Kiste
    Abgesehen davon dass die PPI_speed auf 9600, 19200 und 187500 'eingegrenzt' ist, meine ich da hängts am 'odd'
    Wir hatten das in grauer Vorzeit bei uns im setport.c mal durchgetestet und da ging nur 'even'.
    Den Rest hätte ich auch wohl in etwa so 'umzubauen' angefangen - bei VB hatte ich allerdings früher schon mal einige Schwierigkeiten auch im Timing zur Schnittstelle. Geräte die wundersamerweise in QBasic bestens funktionierten starben in VB umcompilert plötzlich den Timeouttod. Null Ahnung aber wie das 'heutzutage ist' - nur bei Delphi war es in der/ einer dot.net Version auch so. Bei D5 lief das wie geschmiert, in D2005 plötzlich stand alles still
    Join Date
    11.03.2008
    Posts
    35
    Default
    Hallo Tobias, hey der Tipp mit dem "even" war gut, es läuft yipi !
     fds.rfd = libnodave.setPort("COM1", "9600", AscW("e"))  ' step 1, open a connection
                fds.wfd = fds.rfd
    Wenn ich das Programm starte bekomme ich die Meldungen :
    Hello World !
    FD0 : {0:d}
    FD4 : {0:d}
    FD8 : {0:d}
    FD12 : {0:d}
    anstatt "Couldn't open serial port ...."
    das ist doch schon mal was
    Hier der gesamte Code
    Imports System
    Public Class Form1
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        End Sub
            Dim a As Integer
            Dim b(1) As String
            a = test.Main(b)
        End Sub
    End Class
        Class test
                Dim res As Integer
            ' Dim s As String
                fds.wfd = fds.rfd
                        If res = 0 Then
                            If res = 0 Then
                                a = dc.getS32
                                b = dc.getS32
                                c = dc.getS32
                                d = dc.getFloat
                            Else
                            End If
                            dc.disconnectPLC()
                        Else
                        End If
                    Else
                    End If
                Else
                    Return -1
                End If 'fds.rfd >0
            End Function 'Main
        End Class
    Genug für heute, weitergehts im neuen Jahr. In diesem Sinn Frohe Weihnachten und einen Guten Rutsch!
Similar Threads
  1. use LIBNODAVE read data from S7 200 with PPI
    By changjeff in forum Hochsprachen - OPC
    Last Post: 20.11.2017, 09:49
  2. Replies: 7
    Last Post: 09.07.2014, 20:21
  3. libnodave connection problem
    By Nemori in forum Hochsprachen - OPC
    Last Post: 13.03.2012, 19:19
  4. Please help!!! Connection, reading data with S7 300(LibNoDave.dlll, C#)
    By ceasar in forum Werbung und Produktneuheiten
    Last Post: 09.02.2012, 18:54
  5. LibNodave mit Routing und Connection Library...
    By Jochen Kühner in forum Hochsprachen - OPC
    Last Post: 21.06.2010, 11:49
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
