Ergebnis 1 bis 2 von 2
Thema: 302-311
    26.12.2009
    22
    Erhielt 9 Danke für 7 Beiträge
    Rotes Gesicht
    Hi!
    Does anyone have (a link to) the description of this protocol? The 110A pheripheral IO is still alive, and I occationally see it used out there.
    I noticed that the cable is thin, so electrically it might be RS422.
    I just wondered; if I knew the prot, and had some spare time, I could make a driver to these IOs in Step7.
    Regards
    Kaputt
    Zitieren Zitieren 302-311
    kaputt ist offline Benutzer
    26.12.2009
    22
    I found out, at last. It is RK3964 running on a current loop.
    It seem to have a control sign after STX-DLE; NOP/ BASP/ UNBASP / NAK and then the output state is sent from 302 on change. Opposite the 311 initiates the input status sending on change.
