Seite 2 von 2 ErsteErste 12
Ergebnis 11 bis 14 von 14
Thema: Instanz-DB an SCL übergeben
    19.06.2005
    in Bayern ganz oben
    188
    Hi Larry,
    gerne
    TYPE UDT1
    // Datenstruktur CONT_C
      STRUCT
        COM_RST : BOOL ;  //complete restart
        MAN_ON : BOOL  := TRUE;  //manual value on
        PVPER_ON : BOOL ;  //process variable peripherie on
        P_SEL : BOOL  := TRUE;  //proportional action on
        I_SEL : BOOL  := TRUE;  //integral action on
        INT_HOLD : BOOL ;  //integral action hold
        I_ITL_ON : BOOL ;  //initialization of the integral action
        D_SEL : BOOL ;  //derivative action on
        CYCLE : TIME  := T#1S;  //sample time
        SP_INT : REAL ;  //internal setpoint
        PV_IN : REAL ;  //process variable in
        PV_PER : WORD ;  //process variable peripherie
        MAN : REAL ;  //manual value
        GAIN : REAL  := 2.000000e+000;  //proportional gain
        TI : TIME  := T#20S;  //reset time
        TD : TIME  := T#10S;  //derivative time
        TM_LAG : TIME  := T#2S;  //time lag of the derivative action
        DEADB_W : REAL ;  //dead band width
        LMN_HLM : REAL  := 1.000000e+002;  //manipulated value high limit
        LMN_LLM : REAL ;  //manipulated value low limit
        PV_FAC : REAL  := 1.000000e+000;  //process variable factor
        PV_OFF : REAL ;  //process variable offset
        LMN_FAC : REAL  := 1.000000e+000;  //manipulated value factor
        LMN_OFF : REAL ;  //manipulated value offset
        I_ITLVAL : REAL ;  //initialization value of the integral action
        DISV : REAL ;  //disturbance variable
        LMN : REAL ;  //manipulated value
        LMN_PER : WORD ;  //manipulated value peripherie
        QLMN_HLM : BOOL ;  //high limit of manipulated value reached
        QLMN_LLM : BOOL ;  //low limit of manipulated value reached
        LMN_P : REAL ;  //proportionality component
        LMN_I : REAL ;  //integral component
        LMN_D : REAL ;  //derivative component
        PV : REAL ;  //process variable
        ER : REAL ;  //error signal
        sInvAlt : REAL ;
        sIanteilAlt : REAL ;
        sRestInt : REAL ;
        sRestDif : REAL ;
        sRueck : REAL ;
        sLmn : REAL ;
        sbArwHLmOn : BOOL ;
        sbArwLLmOn : BOOL ;
        sbILimOn : BOOL  := TRUE;
      END_STRUCT
    END_TYPE
    DATA_BLOCK DB10  FB41
    // Dummy DB
    // Instanz-DB FB41
    BEGIN
    END_DATA_BLOCK
    FUNCTION FC1 : VOID
    VAR_INPUT
      DB_Nr : INT;    //DB-Nr CONT_C
    END_VAR
    VAR_TEMP
      tAnyDB : ANY;
        _AnyDB AT tAnyDB : STRUCT
          DataTyp : BYTE;
          Count : WORD;
          DBNr : WORD;
          BytePointer : DWORD;
        END_STRUCT;
      tAnyDummy : ANY;
        _AnyDummy AT tAnyDummy : STRUCT
          DataTyp : BYTE;
          Count : WORD;
          DBNr : WORD;
        END_STRUCT;
       tRetVal : INT;
    END_VAR
    BEGIN
      //Any-Pointer auf DB zusammenstellen
      _AnyDB.ID := B#16#10;                 //Muss so sein
      _AnyDB.DataTyp := B#16#2;             //Datentyp Byte
      _AnyDB.Count := W#16#7E;              //Anzahl 126 Bytes
      _AnyDB.DBNr := INT_TO_WORD(DB_Nr);    //DB
      _AnyDB.BytePointer := DW#16#84000000; //Pointer auf DBX0.0
      //Any-Pointer auf Dummy-DB zusammenstellen
      _AnyDummy.ID := B#16#10;                 //Muss so sein
      _AnyDummy.DataTyp := B#16#2;             //Datentyp Byte
      _AnyDummy.Count := W#16#7E;              //Anzahl 126 Bytes
      _AnyDummy.DBNr := W#16#A;                //Dummy DB-Nr 10
      _AnyDummy.BytePointer := DW#16#84000000; //Pointer auf DBX0.0
      //DB-Struktur in Dummy-DB kopieren
      tRetVal := BLKMOV(SRCBLK := tAnyDB, DSTBLK := tAnyDummy);
      //Bausteinaufruf CONT_C mit Dummy Instanz-DB
      CONT_C.DB10();
      //Dummy-DB in DB-Struktur kopieren
      tRetVal := BLKMOV(SRCBLK := tAnyDummy, DSTBLK := tAnyDB);
    END_FUNCTION
    Gruss Daniel
    OSCAT.lib Step 7
  2. Folgender Benutzer sagt Danke zu dalbi für den nützlichen Beitrag:
    Paule (13.05.2010)
  3. #12
    Hallo Daniel,
    leider bin ich mir im Augenblick nicht so sicher, wie ich den Beitrag kommentieren soll ... aber stimmt - das wäre eine mögliche Lösung - ich muß aber gestehen, dass sie mir NICHT gefällt ...
    LL
  4. #13
    19.06.2005
    in Bayern ganz oben
    188
    Hi LL,
    was gefällt Dir den nicht?
    Gruss Daniel
    OSCAT.lib Step 7
  5. #14
    naja ... das :
      CONT_C.DB10();
    ... ist aber vielleicht auch Geschmacksache ...
  1. FB Instanz an FB übergeben
    Von Integer im Forum CODESYS und IEC61131
    Letzter Beitrag: 08.04.2011, 11:23
  2. Instanz-DB
    Von SPS_NEU im Forum Simatic
    Letzter Beitrag: 18.03.2009, 14:08
  3. Antworten: 13
    Letzter Beitrag: 18.01.2008, 12:47
  4. Instanz-DB
    Von titinparma im Forum Simatic
    Letzter Beitrag: 15.10.2007, 17:56
  5. Instanz DB
    Von Flo im Forum Simatic
    Letzter Beitrag: 14.10.2006, 20:04
