Ergebnis 1 bis 2 von 2
Thema: libnodave, libnodaveconnectionlibrary AS511 Protocol
    13.12.2010
    Hi!
    I'am writing here because I have a problem with connection to S5-95U. I have SIMATIC Field PG and I'm trying to connect with AS511 (VS2008 C#):
    using System;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Data;
    using System.Drawing;
    using System.Linq;
    using System.Text;
    using System.Windows.Forms;
    using LibNoDaveConnectionLibrary;
    using LibNoDaveConnectionLibrary.DataTypes;
    using LibNoDaveConnectionLibrary.DataTypes.Blocks;
    using LibNoDaveConnectionLibrary.DataTypes.Step7Project;
    using LibNoDaveConnectionLibrary.STEP7Projectfiles;
    namespace WindowsFormsApplication1
        public partial class Form1 : Form
            public Form1()
                InitializeComponent();
            LibNoDaveConnection myConn = new LibNoDaveConnection("s5");  //AS511 Protocol
            private void button1_Click(object sender, EventArgs e)
              //  Configuration.ShowConfiguration("s5", true);
                this.myConn.Connect();
                    timer1.Enabled = true;
            LibNoDaveValue read = new LibNoDaveValue("EB8");
            private void timer1_Tick(object sender, EventArgs e)
                myConn.ReadValue(read);
                textBox1.Text = read.Value.ToString();
    My program stopped at this.myConn.Connect(); I get an error "Could not creating the Physical Interface(Maybe wrong IP, COM-Port not ready,...)"
    I have COM1 and as I know is free. I don't know libnodave very well and I don't know how to change connection settings... How to connect with S5 using libnodave or libnodaveconnectionlibrary?
    Zitieren Zitieren libnodave, libnodaveconnectionlibrary AS511 Protocol
    17.06.2004
    Offenau
    209
    I've not implemented the S5 functions of libnodave in my ConnectionLibrary. To comunicate with a S5 you have to use libnodave directly or via the libnodave.net.dll!
    Jochen Kühner
    Zitieren Zitieren No...
  1. Antworten: 0
    Letzter Beitrag: 17.02.2010, 16:48
  2. S5 Kommunikation AS511, libnodave
    Von cidex im Forum Simatic
    Letzter Beitrag: 22.11.2008, 09:13
  3. Libnodave as511 Verbindung
    Von saurugst im Forum Hochsprachen - OPC
    Letzter Beitrag: 21.12.2007, 09:49
  4. libnodave und AS511
    Von Ralle im Forum Hochsprachen - OPC
    Letzter Beitrag: 20.02.2007, 00:41
  5. Libnodave für AS511?
    Von hera2006 im Forum Hochsprachen - OPC
    Letzter Beitrag: 14.01.2007, 21:14
