Ergebnis 1 bis 6 von 6
Thema: C# & Libnodave Siemens PLC
    01.11.2012
    Hi all
    Im facing a problem with my C# code.
    Im reading 10 Bytes from the PLC, some integers and float. I want to update my WPF UI textbox continuously.
    i use dispatch timer to run the code but my UI freeze. The first cycle is working fine, but when it starting second cycle it freeze.
    Any help would be greatfull.
    Ludvig
    Zitieren Zitieren C# & Libnodave Siemens PLC
    08.08.2007
    1.059
    define the connection and open it only once and not with every tick.
    before reading the bytes just check the connection status and restart it, if necessary.
    [SIGNATUR]
    [/SIGNATUR]
    mrludvig ist offline Neuer Benutzer
    01.11.2012
    Thx for your reply.
    If i define my connections with "initsuccess" it is the same.
    08.08.2007
    1.059
    may it is necessary to check the isReading state and do nothing while reading
    e.g.
    if (gLPlc.isReading)
                        do { } while (gLPlc.isReading);
    [SIGNATUR]
    [/SIGNATUR]
    17.06.2004
    Offenau
    209
    I've a WPF Example in my ToolBox, wich also uses libnodave. (http://siemensplctoolboxlib.codeplex.com).
    I the Example the complete Display of the Tags works via DataBinding. Maybe you can use this...
    Jochen Kühner
    01.11.2012
    Hi
    Thanks for your reply.
    I fixed my last issue, the problem was to bad definition to my connection. Just like Vierlagig told me...
    i got a new problem that i hope you guys can help me with..
    In my project i need to have an alarm managment, and i want to read out 2 bytes and check whenever a bit is set and then throw out an alarm.
    Do you guys have any example for this?
    Thanks in advice.
  1. Step 7 V11 & AWL & PLC-SIM
    Von derdas im Forum PC- und Netzwerktechnik
    Letzter Beitrag: 06.03.2012, 11:22
  2. Siemens S7-200 & TSAP & LibnoDAve
    Von Dominique Van Huffel im Forum Simatic
    Letzter Beitrag: 19.09.2011, 17:57
  3. B&R Compact PLC programmieren
    Von muuh im Forum Sonstige Steuerungen
    Letzter Beitrag: 04.07.2007, 08:57
  4. Plc-sim&opc
    Von Input im Forum Simatic
    Letzter Beitrag: 18.05.2006, 12:44
  5. plc-open & B&R ACP10_mc
    Von da_kine im Forum Antriebstechnik
    Letzter Beitrag: 28.02.2006, 10:09
