Ergebnis 1 bis 4 von 4
Thema: Set Bit While Button IsPressed. Libnodave c#
    01.11.2012
    Hi
    Im trying to set a single bit while button ispressed.
    This is not working.
    Any sugestion??
    Thx in advice.
    Ludvig
    Zitieren Zitieren Set Bit While Button IsPressed. Libnodave c#
    Erhielt 2.414 Danke für 2.010 Beiträge
    with witch Event do you have connected your "Command_Drain01" ? Witch Handler ?
    Greetings
    mrludvig ist offline Neuer Benutzer
    01.11.2012
    Hi
    I forgot to metion that this C# code is with WPF.
    The Button "Command_Drain01" is in WPF
    <Button Content="Drain" Height="38" HorizontalAlignment="Left" Margin="350,312,0,0" Name="Drain01" VerticalAlignment="Top" Width="114" Click="Command_Drain01" />
    Ludvig
    I have no experience with WPF, but I think, that you use the Button-Event "Click" to start the procedure. "Click" is only raised in the time and also only one time. Not whole the time you are using the Button.
    I suggest you to use the Event "MouseHover". This event is raised the whole time the Mouse is over the Button.
    But I prefer to use "MouseDown" as Event from the Button to set the Bit and the Event "MouseUp" to reset it.
    I think, that will be the best way ...
    Greetings
    Geändert von Larry Laffer (25.11.2012 um 14:55 Uhr)
  1. libnodave 64 bit
    Von tflueckiger im Forum Hochsprachen - OPC
    Letzter Beitrag: 18.08.2010, 09:39
  2. TP170A Button verstecken über Bit
    Von wincc im Forum HMI
    Letzter Beitrag: 22.02.2009, 18:53
  3. Textwechsle im Button bei bit Setzung 1
    Von wachsi im Forum HMI
    Letzter Beitrag: 30.10.2008, 09:09
  4. Libnodave + Excel einzelnes Bit (setzen bzw. abfragen)
    Von Otto im Forum Hochsprachen - OPC
    Letzter Beitrag: 21.12.2006, 17:24
  5. Mit Button Bit in Byte schreiben?
    Von apachler im Forum HMI
    Letzter Beitrag: 31.03.2006, 09:00
