Ergebnis 11 bis 20 von 24
Thema: Werrte flackern im DB
    24.08.2012
    9
    Wie kann ich alle Netzwerke kopieren?
    Oder soll ich einer nach dem anderen einfügen?
    20.06.2003
    Sauerland.NRW.Deutschland
    78
    wie wäre es denn mit quelle generieren. oder drucken in ein pdf dokument
    24.08.2012
    9
    OK hier mal der Baustein villeicht findet ihr ja was.
    FUNCTION_BLOCK "evacuation conveyor 2"
    TITLE =
    AUTHOR : 'A.Kohler'
    VERSION : 0.1
    VAR_INPUT
    release : BOOL ;
    blockade_impulse : BOOL ;
    time_conveyor_forward : TIME ;
    time_blockade_pos : TIME ;
    time_blockade_neg : TIME ;
    time_conveyor_backward : TIME ;
    timer1 : COUNTER ;
    blockade_values : INT ;
    step : INT ;
    END_VAR
    VAR_OUTPUT
    fault_to_many_blockade : BOOL ;
    actual_count_value : INT ;
    END_VAR
    VAR
    released : BOOL ;
    conveyor_forward : BOOL ;
    pos_blockade : BOOL ;
    neg_blockade : BOOL ;
    mem_blockade : BOOL ;
    conveyor_backward : BOOL ;
    pos_edge_conveyor_forwar : BOOL ;
    count_value_word : WORD ;
    count_value_int : INT ;
    evac_pump : BOOL ;
    test : BOOL ;
    END_VAR
    BEGIN
    NETWORK
    TITLE =release delivery conveyor
    U #release;
    S #released;
    UN #release;
    R #released;
    U #released;
    = #evac_pump;
    NETWORK
    TITLE =conveyor forward
    U( ;
    O( ;
    L #step;
    L 6;
    ==I ;
    O( ;
    L #step;
    L 7;
    ==I ;
    NOT ;
    U #released;
    UN #conveyor_backward;
    = #conveyor_forward;
    NETWORK
    TITLE =blockade control pos. edge
    U #conveyor_forward;
    U #blockade_impulse;
    = L 0.0;
    BLD 103;
    CALL "TON" , "time neg blockade eva 2" (
    IN := L 0.0,
    PT := T#5S);
    NOP 0;
    NETWORK
    TITLE =
    U "time neg blockade eva 2".Q;
    U #released;
    = #pos_blockade;
    NETWORK
    TITLE =blockade control neg. edge
    UN #blockade_impulse;
    = L 0.0;
    BLD 103;
    CALL "TON" , "time pos blockade eva 2" (
    IN := L 0.0,
    PT := T#5S);
    NOP 0;
    NETWORK
    TITLE =
    U "time pos blockade eva 2".Q;
    U #released;
    = #neg_blockade;
    NETWORK
    TITLE =blockade
    O #pos_blockade;
    O #neg_blockade;
    = #mem_blockade;
    NETWORK
    TITLE =conveyor backward
    U #mem_blockade;
    = L 0.0;
    BLD 103;
    CALL "TP" , "time conveyor backward 2" (
    IN := L 0.0,
    PT := T#3S);
    NOP 0;
    NETWORK
    TITLE =
    U "time conveyor backward 2".Q;
    U #released;
    = #conveyor_backward;
    NETWORK
    TITLE =counter blockade
    U #mem_blockade;
    ZV #timer1;
    BLD 101;
    U #released;
    L C#0;
    S #timer1;
    R #timer1;
    NOP 0;
    LC #timer1;
    T #count_value_word;
    NOP 0;
    NETWORK
    TITLE =transform into INT
    L #count_value_word;
    BTI ;
    T #count_value_int;
    NOP 0;
    NETWORK
    TITLE =actual count value
    L #count_value_int;
    T #actual_count_value;
    NOP 0;
    NETWORK
    TITLE =compare blockade values
    L #count_value_int;
    L #blockade_values;
    >=I ;
    = #fault_to_many_blockade;
    END_FUNCTION_BLOCK
    Erhielt 2.402 Danke für 2.001 Beiträge
    wenn ich mir das so ansehe, dann wundert es mich, dass es überhaupt funktioniert ...
    Ein IEC-Timer wird mit im STAT-Bereich eines FB eingefügt - z.B. so :
    meinTimer1 : SFB4 ;
    meinTimer2 : SFB4 ;
    meinTimer3 : SFB3 ;
    im späteren Code rufst du dann diese Instanz auf :
    call meinTimer1
    ... und übergibst dem dann die relevanten Info's.
    Wichtig auch : nie die gleiche Instanz 2 mal aufrufen - das geht dann nämlich auch wieder nicht.
    Den Rest kaghabe ich mir nicht angesehen ...
  5. #15
    11.09.2007
    Suedwestpfalz
    81
    Mal 'ne Frage an den TE -
    wie oft wird dieser FB im Programm aufgerufen?
    Die SFBs haben direkt zugewiesene Instanzen, daraus folgt der FB darf nur EINMAL im im Programm aufgerufen werden.
  6. #16
    @Clipper:
    Er übergibt einen TIME-Wert als Instanz an den SFB ...
  7. #17
    11.09.2007
    Suedwestpfalz
    81
    Ich meine
    IN := L 0.0,
    PT := T#5S)
    Das riecht für mich nach einem eigenen Instanz-DB...
  8. #18
    11.09.2007
    Suedwestpfalz
    81
    Oder bin ich jetzt auf dem falschen Dampfer ????
  9. #19
    ... im Prinzip nicht - aber schau mal in der Deklaration ... die Variable ist vom Typ TIME ...
  10. #20
    11.09.2007
    Suedwestpfalz
    81
    Die wird aber nicht mehr verwendet...
  1. Antworten: 2
    Letzter Beitrag: 28.11.2012, 13:19
  2. Probleme mit Beckhoff Dimmer (KL2751) - flackern
    Von ohm200x im Forum CODESYS und IEC61131
    Antworten: 21
    Letzter Beitrag: 01.02.2011, 22:49
  3. Flackern von Tooltips und Anwendungen
    Von demmy86 im Forum PC- und Netzwerktechnik
    Letzter Beitrag: 09.12.2008, 19:50
  4. S7-200 ASi Bus Eingänge flackern
    Von Daimonion im Forum Simatic
    Letzter Beitrag: 14.08.2008, 18:43
  5. Antworten: 30
    Letzter Beitrag: 01.10.2007, 14:57
