Seite 3 von 8 ErsteErste 12345 ... LetzteLetzte
Ergebnis 21 bis 30 von 76
Thema: ACCON-NetLink-USB compact
  1. #21
    30.12.2013
    6
    I did as u said : When Using PLCConnect function: - is An error happend at the Following: PLCConnect: PLC not found same error
    None of the stations are in online in lifelist. what to do?
  2. #22
    22.11.2007
    6
    Erhielt 89 Danke für 62 Beiträge
    Ideas:
    1. What Tools do you use for driver configuration (what is the driver type)? Is the driver reachable through these tools?
    2. more bold doesn't help here
  3. #23
    30.12.2013
    6
    Through MCT10 tool the driver is reachable and I could access it using some mft PRofibus adapter.. I use MCT10 to configure the driver..
    I couldnt access the driver using ACCON-NetLink-USB Compact (which is also a Profibus adapter)..
  4. #24
    22.11.2007
    6
    I don't know MCT10 - is the driver a siemens kompatible SINAMICS or Micromaster?
    i think that are the ones AGLink supports - what make you think AGLink can work with your driver - is there a compatiblity list or something?
  5. #25
    30.12.2013
    6
    Yes the driver is SIEMENS compatible .. Bit more, The driver can be accessed using Siemens CP5711, 5611, 5613 profibus adapters..
    I am trying to access the same driver using Accon Netlink USB compact adapter , it is not working this is my problem precisely.
    Geändert von natarajan (31.12.2013 um 06:59 Uhr)
  6. #26
    22.11.2007
    6
    so your AGLink program works if you using the CPs, right?
  7. #27
    30.12.2013
    6
    No the driver is not accessible through AGlink program when using CPs...
  8. #28
    22.11.2007
    6
    nice unreadable micro screenshots
    and can you connect to the driver with your MTC10 program when using USB Compact? (i think you need to switch something in the Siemens CP config)
  9. #29
    30.12.2013
    6
  10. #30
    30.12.2013
    6
    No I cannot connect it through MCT10 also with USB compact .. everything is fine with Cp configuration..
    Geändert von natarajan (31.12.2013 um 07:38 Uhr)
  1. Accon Netlink Pro Compact IP finden
    Von Jorrit im Forum Simatic
    Letzter Beitrag: 16.12.2015, 08:45
  2. Antworten: 7
    Letzter Beitrag: 11.11.2013, 13:31
  3. Accon-NetLink-PRO compact und Windows 7 (64 bit)
    Von Kallemann im Forum Simatic
    Letzter Beitrag: 26.10.2013, 18:22
  4. Antworten: 2
    Letzter Beitrag: 30.05.2012, 08:16
  5. Accon NetLink Pro compact kleine Problemchen
    Von Matze001 im Forum Feldbusse
    Letzter Beitrag: 16.02.2012, 09:55
