Seite 5 von 8 ErsteErste ... 34567 ... LetzteLetzte
Ergebnis 41 bis 50 von 76
Thema: ACCON-NetLink-USB compact
  1. #41
    30.12.2013
    6
    No both are not connected at sametime.
    I unplug one and connect another to my PC..
    It is not PLC , its a drive ....
    Geändert von natarajan (31.12.2013 um 11:03 Uhr)
  2. #42
    27.10.2005
    Schwäbisch Gmünd
    640
    The PC connection is not the problem, I want to know the profibus connection.
    Do you have only the drive and nothing else connected to profibus?
    Rainer Hönle
    DELTA LOGIC GmbH
  3. #43
    30.12.2013
    6
    Yes only the drive is connected to Profibus ...
  4. #44
    30.12.2013
    6
    Hi, I tried all the ways which you mentioned still I am unable to access my drive.. Please help me on connection to drive..
  5. #45
    16.03.2006
    Franken
    30
    Erhielt 942 Danke für 819 Beiträge
    first Screen in Post #36.
    On the SIEMENS CP the Option "is the only master on bus" is set, and the Screen in Post #37 show in the LifeListCommand 2 Entries.
    This 2 Entries i think are 1 and 2 like the CP5711 dialog in post #36.
    Check if there a option "master on the bus" is availabe for the AGLink, the MCT10 is a passive Slave and needs a PROFIBUS Master for communication.
    The SIEMENS CP support this Master option but the AGLINK?
    Regards
    Christoph
  6. #46
    30.12.2013
    6
    In AGLink there is no option available under S7-Netlink USB to set my PC as master..
    I also had a doubt that how to set my PC as master when communicating Accon-Netlink USB compact via AGLink?? I think my drive search for Master ...
    but in AGlink there is no option available to make my PC as master..
    could you please check it ?
    Geändert von natarajan (02.01.2014 um 11:14 Uhr)
  7. #47
    27.10.2005
    Schwäbisch Gmünd
    640
    Only for testing: do you have any other master (for example a PLC), which you can connect to the bus?
    Rainer Hönle
    DELTA LOGIC GmbH
  8. #48
    27.10.2005
    Schwäbisch Gmünd
    640
    It is not an problem with ACCON-AGLink, it is a problem with profibus an ACCON-NetLink-USB compact. So we can use ACCON-AGLink only for testing and verification.
    Rainer Hönle
    DELTA LOGIC GmbH
  9. #49
    30.12.2013
    6
    No i dont have PLC.. is there any other way to do ?
    Geändert von natarajan (02.01.2014 um 11:22 Uhr)
  10. #50
    16.03.2006
    Franken
    30
    in post #34
    "any plc can be detected by accon netlink usb compact , if it uses the simatic s7-200.."
    So I think the Adapter "ACCON-NetLink-USB compact" works correct if a active device is connected.
    Hmm no PLC? But you have a SIEMENS CP on your side? Can your make a test with a connection between SIEMENS CP and NetLink?
  1. Accon Netlink Pro Compact IP finden
    Von Jorrit im Forum Simatic
    Letzter Beitrag: 16.12.2015, 08:45
  2. Antworten: 7
    Letzter Beitrag: 11.11.2013, 13:31
  3. Accon-NetLink-PRO compact und Windows 7 (64 bit)
    Von Kallemann im Forum Simatic
    Letzter Beitrag: 26.10.2013, 18:22
  4. Antworten: 2
    Letzter Beitrag: 30.05.2012, 08:16
  5. Accon NetLink Pro compact kleine Problemchen
    Von Matze001 im Forum Feldbusse
    Letzter Beitrag: 16.02.2012, 09:55
