Seite 7 von 8 ErsteErste ... 5678 LetzteLetzte
Ergebnis 61 bis 70 von 76
Thema: ACCON-NetLink-USB compact
  1. #61
    16.03.2006
    Franken
    30
    Erhielt 917 Danke für 798 Beiträge
    @LowLevelMahn
    4.) nastarjan have no PLC only the Danfoss FC102 Drive !
    In Post #34 he tell that's the Adapter work with PLC S7-200 correctly, but at this time he have no PLC!
    The Danfoss work with DPV1 Parameter Sequences to communicate with the MCT10 Software Suite.
    To establish a DPV1 connection to a passive PROFIBUS Slave you need a PROFIBUS Master Class 2 , this mode is
    available on the SIEMENS CP's when you set the Option "Is the Only Master in the bus".
    So this doesn't look like a protocol problem but a Operating Mode Problem of the NetLink USB Compact!
  2. #62
    22.11.2007
    6
    Erhielt 89 Danke für 62 Beiträge
    his hardware scenario seems to be a bit floaty
    could that explain why he can't find the driver on the lifelist?
    it will not work with AGLink if the danfoss driver isn't speeking the siemens driver protocol, but he could use the USB Compact for driver configuration through MCT10 then
  3. #63
    16.03.2006
    Franken
    30
    No with the USB Compact he can't configure the danfoss trough MCT10 because the Software needs the Checkbox "is the only master on the bus" (MCT10 manual).
  4. #64
    27.10.2005
    Schwäbisch Gmünd
    630
    If the the ACCON-NetLink-USB compact can't go online, the AGL_InitAdapter returns an error. If the check box "Automatic.." isn't check, the adapter will go online even if no other master is present. So I don't know, where the problem ist. I think it is best, to use an additional master (Siemens CP) for testing (thanks to ChristophD). Hope that helps.Btw: ACCON-NetLink-USB (compact) and ACCON-NetLink-PRO (compact) can be used with the MCT-Software.
    Rainer Hönle
    DELTA LOGIC GmbH
  5. Folgender Benutzer sagt Danke zu Rainer Hönle für den nützlichen Beitrag:
    natarajan (08.01.2014)
  6. #65
    30.12.2013
    6
    Thanks to ChristophD and Rainer .. I will try the method Christophd said.
  7. #66
    30.12.2013
    6
    Hi , sorry for the delay...PLC is detecting with Accon Netlink USB compact..
    Danfoss FC102 board is also detecting but I dont know how to read and write parameter from the Danfoss board..
    AGL_DRIVE_write and AGL_Drive_read is not working...
  8. #67
    27.10.2005
    Schwäbisch Gmünd
    630
    As I wrote above, the ACCON-AGLink drive functions are only for Micromaster and Sinamics. You must use your Danfoss software to change the parameters.
    Btw: what was the problem of not seeing the drive in the lifelist? What did you change?
    Rainer Hönle
    DELTA LOGIC GmbH
  9. #68
    30.12.2013
    6
    I dont know how it is showing drive in lifelist (surprise).. Danfoss software (MCT10) wont work with Accon Netlink USB compact ..
    So, is that I should connect PLC and Danfoss Drive via Accon Netlink USB compact and do read &write???
    Geändert von natarajan (09.01.2014 um 08:34 Uhr)
  10. #69
    27.10.2005
    Schwäbisch Gmünd
    630
    One last time: you must see your drive in the lifelist (test it with API-Guide or AGLink40_Config), then your Danfoss software can access your drive via ACCON-NetLink-USB compact. If you don't see it in the lifelist, nobody can access the drive via ACCON-NetLink-USB compact.
    What do you mean with #66? What have you tested the last days? What are you doing? What ist your equipement? Sorry, but I don't have a crystal ball to guess what ist going on. And your informations are very rare.
    Rainer Hönle
    DELTA LOGIC GmbH
  11. #70
    30.12.2013
    6
    Hi one last time : could you please tell me why with AGL_Drive_write and AGL_Drive_read I couldnt read/write parameter from danfoss drive.
    Even though the drive is showing in lifelist...
    Thanks...
  1. Accon Netlink Pro Compact IP finden
    Von Jorrit im Forum Simatic
    Letzter Beitrag: 16.12.2015, 08:45
  2. Antworten: 7
    Letzter Beitrag: 11.11.2013, 13:31
  3. Accon-NetLink-PRO compact und Windows 7 (64 bit)
    Von Kallemann im Forum Simatic
    Letzter Beitrag: 26.10.2013, 18:22
  4. Antworten: 2
    Letzter Beitrag: 30.05.2012, 08:16
  5. Accon NetLink Pro compact kleine Problemchen
    Von Matze001 im Forum Feldbusse
    Letzter Beitrag: 16.02.2012, 09:55
