Seite 1 von 8 123 ... LetzteLetzte
Ergebnis 1 bis 10 von 76
Thema: ACCON-NetLink-USB compact
    30.12.2013
    6
    Lächeln
    I am using Accon-Netlink-USB-compact to establish PROFIBUS connection between PC and drive ( not the PLC). I am not able to read and write the device parameter. I used the API's (drive_readmix, drive_writeMix) but still I couldnt read/write to the device.
    I have a doubt , is it possible to use Accon-Netlink-USB compact and establish the PROFIBUS connection without PLC ? if it is so, please tell me how to do read and write from/to device..
    Thanks alot,
    natarajan.
    Zitieren Zitieren ACCON-NetLink-USB compact
    27.10.2005
    Schwäbisch Gmünd
    630
    I think you are using ACCON-AGLink. Do you get a connection to the drive? If not, in which function do you get an error? What is the error code?
    Rainer Hönle
    DELTA LOGIC GmbH
    30.12.2013
    6
    yes i am using Accon-AGLink latest version ,
    open connection, dial-up , init adapter (adapter is detecting), exit adapter, hang-up, close device are successful..
    AGL_DriveReadMix, AGL_DrivewriteMix functions producing error.
    error code is -1048569 ( the error code is Device Not Opened)...
    How to make read and write??
    Thanks..
    Geändert von natarajan (30.12.2013 um 09:31 Uhr)
    27.10.2005
    Schwäbisch Gmünd
    630
    You got AGL40_SUCCESS from AGL_InitAdapter? To read parameters from the drive, you must use AGL40_PLCConnect with the busaddress of the drive to get a connection to the drive. Which result do you get from this function?
    Rainer Hönle
    DELTA LOGIC GmbH
    30.12.2013
    6
    Yes, I got AGL40_SUCCESS from AGL_InitAdapter.. The API AGL40_PLCconnect is not successful error code is ( -720868 ) which means PLC not found..
    I have entered the bus parameters properly still i am getting error in PLCConnect.. Please reply..
    Thanks.
    Geändert von natarajan (30.12.2013 um 10:47 Uhr)
    27.10.2005
    Schwäbisch Gmünd
    630
    Which busaddress has the drive? Which parameters do you use for AGL_PLCConnect?
    Rainer Hönle
    DELTA LOGIC GmbH
    30.12.2013
    6
    I used PlcNr paramter in PLCconnect function,..
    The drive is in address - 2..
    still it is not connecting...
    27.10.2005
    Schwäbisch Gmünd
    630
    Please post you code. 2 is normal the address of the plc and not the address of the drive! You must use the profibusaddress of the drive for AGL_PLCConnect.
    Rainer Hönle
    DELTA LOGIC GmbH
    30.12.2013
    6
    code :
    int doPLCconnect(int timeout, long userval)
    int connnr = 1;
    int devnr = 0;
    int plcnr = 2;
    int result = AGL_PLCConnect(devnr, plcnr, &connnr, timeout, userval);
    if (result == AGL40_SUCCESS)
    std::cout<<"plc connect is successfull"<<std::endl;
    return 0;
    std::cout<<"error in PLC connect"<<std::endl;
    return result;
    this is the function I used for PLC connect..
    27.10.2005
    Schwäbisch Gmünd
    630
    And one last time: which profibusaddress has the drive? What happens, if you use this address? see #4 ...
    Rainer Hönle
    DELTA LOGIC GmbH
  1. Accon Netlink Pro Compact IP finden
    Von Jorrit im Forum Simatic
    Letzter Beitrag: 16.12.2015, 08:45
  2. Antworten: 7
    Letzter Beitrag: 11.11.2013, 13:31
  3. Accon-NetLink-PRO compact und Windows 7 (64 bit)
    Von Kallemann im Forum Simatic
    Letzter Beitrag: 26.10.2013, 18:22
  4. Antworten: 2
    Letzter Beitrag: 30.05.2012, 08:16
  5. Accon NetLink Pro compact kleine Problemchen
    Von Matze001 im Forum Feldbusse
    Letzter Beitrag: 16.02.2012, 09:55
