24 | 05:41:13 | 6 - Info | 04/07/2014 15:52:30
Apr 7 14:52:22 02[CFG] <DERF|2> no alternative config found
24 | 05:41:13 | 4 - Warning | 04/07/2014 15:52:30
Apr 7 14:52:22 02[CFG] <DERF|2> constraint check failed: RULE_CRL_VALIDATION is SKIPPED, but requires at least GOOD
Apr 7 14:52:22 02[IKE] <DERF|2> authentication of 'C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9' with RSA successful
Apr 7 14:52:22 02[CFG] <DERF|2> using trusted certificate "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:52:22 02[CFG] <DERF|2> reached self-signed root ca with a path length of 0
Apr 7 14:52:22 02[CFG] <DERF|2> certificate status is not available
Apr 7 14:52:22 02[CFG] <DERF|2> checking certificate status of "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:52:22 02[CFG] <DERF|2> using trusted ca certificate "C=DE, O=Siemens, CN=PBB5F-G7244"
Apr 7 14:52:22 02[CFG] <2> selected peer config "DERF"
Apr 7 14:52:22 02[CFG] <2> looking for RSA signature peer configs matching 77.119.230.88...46.220.123.234[C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9]
Apr 7 14:52:22 02[IKE] <2> received end entity cert "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:52:22 02[IKE] <2> received cert request for 'C=DE, O=Siemens, CN=PBB5F-G7244'
Apr 7 14:52:21 12[IKE] <2> received retransmit of request with ID 0, retransmitting response
Apr 7 14:52:21 01[IKE] <2> received retransmit of request with ID 0, retransmitting response
Apr 7 14:52:20 14[IKE] <2> sending cert request for "C=DE, O=Siemens, CN=PBB5F-G7244"
24 | 05:41:02 | 6 - Info | 04/07/2014 15:52:20
Apr 7 14:52:19 16[IKE] <2> received retransmit of request with ID 0, retransmitting response
Apr 7 14:52:18 02[IKE] <2> 46.220.123.234 is initiating a Main Mode IKE_SA
Apr 7 14:52:18 02[IKE] <2> received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
24 | 05:40:32 | 6 - Info | 04/07/2014 15:51:50
Apr 7 14:51:46 02[CFG] <DERF|1> no alternative config found
24 | 05:40:32 | 4 - Warning | 04/07/2014 15:51:50
Apr 7 14:51:46 02[CFG] <DERF|1> constraint check failed: RULE_CRL_VALIDATION is SKIPPED, but requires at least GOOD
Apr 7 14:51:46 02[IKE] <DERF|1> authentication of 'C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9' with RSA successful
Apr 7 14:51:46 02[CFG] <DERF|1> using trusted certificate "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:51:46 02[CFG] <DERF|1> reached self-signed root ca with a path length of 0
Apr 7 14:51:46 02[CFG] <DERF|1> certificate status is not available
Apr 7 14:51:46 02[CFG] <DERF|1> checking certificate status of "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:51:46 02[CFG] <DERF|1> using trusted ca certificate "C=DE, O=Siemens, CN=PBB5F-G7244"
Apr 7 14:51:46 02[CFG] <1> selected peer config "DERF"
Apr 7 14:51:46 02[CFG] <1> looking for RSA signature peer configs matching 77.119.230.88...46.220.123.234[C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9]
Apr 7 14:51:46 02[IKE] <1> received end entity cert "C=DE, O=Siemens, CN=PBB5F-UDD02DCF3-G83E9"
Apr 7 14:51:46 02[IKE] <1> received cert request for 'C=DE, O=Siemens, CN=PBB5F-G7244'
Apr 7 14:51:44 01[IKE] <1> received retransmit of request with ID 0, retransmitting response
Apr 7 14:51:43 12[IKE] <1> received retransmit of request with ID 0, retransmitting response
Apr 7 14:51:43 15[IKE] <1> sending cert request for "C=DE, O=Siemens, CN=PBB5F-G7244"
Apr 7 14:51:42 13[IKE] <1> received retransmit of request with ID 0, retransmitting response
Apr 7 14:51:41 02[IKE] <1> 46.220.123.234 is initiating a Main Mode IKE_SA
Apr 7 14:51:41 02[IKE] <1> received draft-ietf-ipsec-nat-t-ike-02\n vendor ID |
