Ergebnis 1 bis 10 von 14
Thema: DotNetSiemensPLCToolBoxLibrary - "var list"
    12.09.2014
    Hello,
    i 'm sorry but i can speak only English and Italian. I wrote here because this is the only place where i can find help.
    I used this library for simple tasks like connection and reading/writing simple data (like int, bit, byte) and complex data (like string and struct).
    Now i need the list of the variables used in the PLC. For example i need to know all the variables declared in DB1 and their values.
    Is it possible?
    Thank you
    Roberto
    Geändert von R3DLINE (16.09.2014 um 17:33 Uhr)
    Zitieren Zitieren DotNetSiemensPLCToolBoxLibrary - "var list"
    R3DLINE ist offline Neuer Benutzer
    12.09.2014
    No one can help me?
    27.06.2009
    am Nordharz
    443
    Erhielt 914 Danke für 739 Beiträge
    Maybe someone can help you, if the question is in English.
    12.09.2014
    The question is in english, chrome translated it before i posted -.-'
    27.06.2009
    am Nordharz
    443
    Do you kidding me? I want to help you!
    Ciao,
    i 'm dispiace ma posso solo parlare inglese e italiano. Ho scritto qui:. Perché questo è l'unico posto dove posso trovare aiuto
    ho usato questa biblioteca per compiti semplici come connessione e di lettura / scrittura di (stringhe, struct) dati semplici (int, bit, byte) e complessi.
    Ora ho bisogno una lista della variabile in uso nel controllore. Ad esempio, ho bisogno di sapere la variabile dichiarata in DB1 ed i loro valori.
    E 'possibile?
    Grazie
    Roberto
    http://webcache.googleusercontent.co...&ct=clnk&gl=de
    12.09.2014
    You don't understand me...
    this is the english question that i wrote translated in a sort of pseudo-italian language. Chrome translated my question before i pressed the publish button
    17.06.2004
    Offenau
    209
    You can read the DB from the PLC with the Lib.
    Maybe this Code Helps you...
                myConn = newPLCConnection("SimpleCSharpDemonstrationConnection");
                myConn.Connect();
                var bytes = myConn.PLCGetBlockInMC7("DB1");
                var db = MC7Converter.GetAWLBlock(bytes, 0) as S7DataBlock;
                var plctagList = db.Structure.Children.Cast<S7DataRow>().Flatten(x => x.Children.Cast<S7DataRow>()).Select(x => x.PlcTag);
    Jochen Kühner
    12.09.2014
    Thank you Jochen Kühner.
    I have this error with your code:
    System.Collections.Generic.IEnumerable<DotNetSiemensPLCToolBoxLibrary.DataTypes. Blocks.Step7V5.S7DataRow> don't contain a definition of Flatten
    And i have another question.. if i want to list also the variables used in OB1? i can use the same method?
    Thank you again
    17.06.2004
    Offenau
    209
    I don't understand what you mean with "if i want to list also the variables used in OB1? i can use the same method?"
    The Flatten is a ExtesionMethod defined in my Assembly, you must add a using to "
    DotNetSiemensPLCToolBoxLibrary.General"!
    And also maybe you need the newest DLL
    Jochen Kühner
    12.09.2014
    Thank you for your hints, i updated the lib and added a using statement: the code compile.
    Now i have a problem at runtime.
    after the call to GetAWLBlock i get a warning (index out of range) in the Class DotNetSiemensPLCToolBoxLibrary.PLCs.S7_xxx.MC7.Parameter
    in the function GetVarTypeEN
    case 0x11: //Struct
                            if (Arry) pos += 7;
                            Result = S7DataRowType.STRUCT;
                            var akPar = new S7DataRow(VarNamePrefix + VarCounter.ToString(), Result, myBlk) { StartValue = startVal };
                            currPar.Add(akPar);
                            VarCounter++;
                            max = interfaceBytes[pos + 2] - 1;
                            for (i = 0; i <= max; i++)
                                if ((interfaceBytes[pos + 3] == 0x11) || (interfaceBytes[pos + 3] == 0x10))   <-----HERE
    I'm not sure what's happening here, but... i tried with different DB and also with a DB without struct... but the code fails always here.
    Any suggestion?
  1. Antworten: 8
    Letzter Beitrag: 07.05.2015, 08:25
  2. Antworten: 6
    Letzter Beitrag: 06.01.2013, 14:49
  3. "Index Pulse", "Home Switch" und "Position Limit Switch"
    Von senmeis im Forum Antriebstechnik
    Letzter Beitrag: 07.03.2011, 11:21
  4. Antworten: 0
    Letzter Beitrag: 18.03.2009, 14:20
  5. Antworten: 2
    Letzter Beitrag: 15.06.2006, 12:56
