Ergebnis 1 bis 6 von 6
Thema: Libnodave & excel
    21.04.2016
    Hi All,
    I am looking for any document to explain libnodave library and how can i integrate it inside excel to get some reading from siemens microbox over TCP/IP.
    Thanks In Advance.
    Moelsayed
    Zitieren Zitieren Libnodave & excel
    925
    in Libnodave package are included html-files with explanation of the most important functions (I think a folder with name "doc")
    Here in FAQ [Libnodave] Beispiel TCP Verbindung zu S7-Welt you will find a working Excel-example. In the Excel-file open the VBA-module, you will find declarations and short descriptions of the used functions from the Library.
    moelsayed ist offline Neuer Benutzer
    21.04.2016
    [QUOTE = PN / DP; 619496] Hi, in Libnodave package are included html files with explanation of the mostimportant functions (I think a folder with name "doc") Here in wants to find a working Excel example. In the Excel file open the VBA module, you will find declarations and short descriptions of the used functions from the Library. Harald [/ QUOTE]
    Thank you very much
    Moelsayed
    21.04.2016
    Hi Harald, I went to the previous link and i tried to write my question but i could not Because The replying options were not active, HOWEVER so please could you guide me where and what can i do Because I am really need this tool. Many thanks, Moelsayed
    925
    Hi Moelsayed,
    in FAQ-area it's not possible to reply.
    Libnodave
    1. download Libnodave package from http://libnodave.sourceforge.net/
    2. unzip Libnodave package
    3. copy libnodave.dll to C:\WINDOWS\system32
    4. take a look into the unpacked files - in folder "doc" you will find documentation, start with index.html
    5. take a look into the folder "Excel And VB", open Modul12.bas with notepad.exe and read
    (6. you can copy the Modul12.bas into your xls-file: open Excel + open Extra > Macro > Visual basic editor (or so) + file > file import)
    Excel example
    7. go to FAQ: Programmbeispiel für EXCEL 64-Bit und 32-Bit and download the attached file Tankanzeigen_mit_Libnodave_64.xls.zip
    8. unzip
    9. open the Tankanzeigen_mit_Libnodave_64.xls
    10. go to sheet "Tanks" with an example for connect to S7-300 via CP343-1 or the PN-interface of CPU
    11. change the red IP-address to IP of your PLC
    12. put a DB123 with at least 8 REAL-variables in your PLC and manipulate the values in range 0.0 ... 40.0 or 65.0
    13. click the button [Werte aus PLC lesen] --> this call the Sub readFromFAFM() in Modul10 --> this will read DB123.DBB0...DBB23 from the PLC and show in chart
    14. read Modul10. there are short descriptions at the 32-Bit declarations. 64-Bit declarations are without description - see 32-Bit
    21.04.2016
    Thanks a lot
    Moelsayed
    Sent from my GT-I9505 using Tapatalk
  1. Step 7 Excel Siemens libnodave
    Von zmnck im Forum Simatic
    Antworten: 13
    Letzter Beitrag: 05.12.2017, 17:42
  2. Sonstiges libnodave & Logo8 & VB.Net
    Von kiter20 im Forum Simatic
    Antworten: 19
    Letzter Beitrag: 07.09.2015, 00:20
  3. Sonstiges libnodave & vb2010 & logo
    Von drake im Forum Simatic
    Antworten: 29
    Letzter Beitrag: 25.05.2015, 21:58
  4. Siemens S7-200 & TSAP & LibnoDAve
    Von Dominique Van Huffel im Forum Simatic
    Letzter Beitrag: 19.09.2011, 17:57
  5. Libnodave und Excel
    Von Joe im Forum Hochsprachen - OPC
    Letzter Beitrag: 23.01.2007, 11:19
