Hallo, ich hab mir mal das Java Beispiel von B&R angeschaut um Prozessvariablen auszulesen. Weiß jemand wie ich da nun Variablen auslesen kann? Was muss ich übergeben?
B&R Beispiel mit meinem Code am Ende:
* To change this template, choose Tools | Templates
* and open the template in the editor.
import java.io.BufferedReader;
import java.io.InputStreamReader;
import java.io.OutputStreamWriter;
import java.net.URL;
import java.net.URLConnection;
import java.net.URLEncoder;
import java.util.logging.Level;
import java.util.logging.Logger;
public class BR_ASP_Request
public static String readPv(String variable, String target)
try
// Construct data
String data = URLEncoder.encode("redirect", "UTF-8") + "=" + "/response.asp";
data += "&" + URLEncoder.encode("variable", "UTF-8") + "=" + URLEncoder.encode(variable, "UTF-8");
data += "&" + URLEncoder.encode("value", "UTF-8") + "=";
data += "&" + URLEncoder.encode("read", "UTF-8") + "=" + URLEncoder.encode("1", "UTF-8");
URL url = new URL("http://" + target + ":80/goform/ReadWrite");
return pvAccess(data, url);
catch (Exception ex)
Logger.getLogger(BR_ASP_Request.class.getName()).log(Level.SEVERE, null, ex);
return "Error";
public static String writePv(String variable, String value, String target)
try
// Construct data
data += "&" + URLEncoder.encode("value", "UTF-8") + "=" + URLEncoder.encode(value, "UTF-8");
data += "&" + URLEncoder.encode("write", "UTF-8") + "=" + URLEncoder.encode("1", "UTF-8");
return "Error";
public static String pvAccess(String data, URL url)
String line = null;
String response = "";
try
// Send data
URLConnection conn = url.openConnection();
conn.setConnectTimeout(3);
conn.setDoOutput(true);
OutputStreamWriter wr = new OutputStreamWriter(conn.getOutputStream());
wr.write(data);
wr.flush();
wr.close();
// Get the response
BufferedReader rd = new BufferedReader(new InputStreamReader(conn.getInputStream()));
while ((line = rd.readLine()) != null)
// For AR < 3.08
line = line.replace("<!-- B&R ASP Webserver -->","" );
response += line;
wr.close();
rd.close();
return response;
catch (Exception e)
System.out.println(e.toString());
return e.toString();
public static void main(String[] args){
System.out.println(BR_ASP_Request.readPv("XXX.XXX.XXX.XXX,"AI[1]"));
