Serial communication Beckhoff CX2030
Akram Louati
I'm a new user of the Beckhoff plc. I'm trying to communicate with a device using the serial communication by sending a string. I'm using the library tc2.SerialCom and twincat 3. I created a function block as follows:
FUNCTION_BLOCK FB_SerialCom
VAR_IN_OUT
 TxBuffer : ComBuffer;
END_VAR
VAR
  Send_String :Sendstring;
END_VAR
VAR_OUTPUT
  bSendBusy : BOOL;
  eSendErrorID : ComError_t;
END_VAR
 Send_String(
 SendString := '%R1Q,9027:1.0,1.0,0,1,0\r\n\n',
 TXbuffer := TxBuffer,
 Busy => bSendBusy,
 Error => eSendErrorID);
and I did the the Background communication in the main program as follows:
PROGRAM MAIN
VAR
 stIn_PcCom AT %I* : PcComInData; (* linked to the port in the TwinCAT System Manager *)
 stOut_PcCom AT %Q* : PcComOutData; (* linked to the port in the TwinCAT System Manager *)
 TxBufferPcCom : ComBuffer;
 RxBufferPcCom : ComBuffer;
   (* background communication with the PC COM port device *)
    fbPcComCtrl       : SerialLineControl;
    bPcComCtrlError   : BOOL;
    ePcComCtrlErrorID : ComError_t;
END_VAR
fbPcComCtrl(
    Mode      := SERIALLINEMODE_PC_COM_PORT,
    pComIn    := ADR(stIn_PcCom),
    pComOut   := ADR(stOut_PcCom),
    SizeComIn := SIZEOF(stIn_PcCom),
    Error     => bPcComCtrlError,
    ErrorID   => ePcComCtrlErrorID,
    TxBuffer  := TxBufferPcCom,
    RxBuffer  := RxBufferPcCom );
The parameter Busy is false but nothing is coming to the device. What could be the reason for that?
Thank you in advance.
This was my first fault. now I called
FB_SerialCom in the main. The parameter Busy stays always TRUE and the Error is : COMERROR_TXBUFFOVERRUN. I don't see any changes in the output.
Hier is the PROGRAM MAIN now:
PROGRAM MAIN
VAR
  Serial:FB_SerialCom;
END_VAR
fbPcComCtrl(
 Serial(TxBuffer:=TxBufferPcCom);
