A
Anonymous
Guest
habe follgendes programm in vba(excel) müsste das in wincc zum laufen bringen...
Sub test()
Dim Dateiname As String
Dim strtmp As String
Dim HEUTE As Date
Dim Jetzt As Date
Dim Eintrag As String
Dim BTAKKZ, BTFAUN, BTXUNT, BTAPNR, BTIDNR, BTMEKZ As String
Dim BTYUNV, BTYUNB, BTYSTT, BTYENT As String ' Datum
Dim BTUNZV, BTUNZB, BTSZTT, BTEZTT As String ' Uhrzeit
Dim BTPONR As Integer
Dim BTVBME As Currency
Dim Auftragsnummer, Teilenummer As String ' WinCC Variable
Dim Chargennummer As Integer ' WinCC Variable
Dim Verbrauchsmenge As Currency ' WinCC Variable evt auch single
Dim Einheit As String 'WinCC Variable max 2Zeichen
HEUTE = Date
Jetzt = Time
'Vorläufige Parameterversorgung statt WinCC Variable
Auftragsnummer = "BUE0815"
Teilenummer = "4711FH" 'von Masterplatte
Chargennummer = 1
Verbrauchsmenge = 222.33
Einheit = "kg"
Dateiname = "c:\AccessÜbungen\G10_" & Format(HEUTE, "ddmmyyyy") & ".csv"
MsgBox Dateiname
' Snapshot bei Charge Start
BTAKKZ = "AS"
BTFAUN = Auftragsnummer
BTXUNT = ""
BTYUNV = "" 'Format(HEUTE, "dd.mm.yyyy")
BTUNZV = "" 'Format(Jetzt, "hh:mm:ss")
BTYUNB = "" 'Format(HEUTE, "dd.mm.yyyy")
BTUNZB = "" 'Format(Jetzt, "hh:mm:ss")
BTAPNR = "G10"
BTPONR = Chargennummer
BTYSTT = Format(HEUTE, "dd.mm.yyyy")
BTSZTT = Format(Jetzt, "hh:mm:ss")
BTYENT = "" 'Format(HEUTE, "dd.mm.yyyy")
BTEZTT = "" 'Format(Jetzt, "hh:mm:ss")
BTIDNR = Teilenummer
BTVBME = Verbrauchsmenge
BTMEKZ = Einheit
Eintrag = BTAKKZ & "," & BTFAUN & "," & BTXUNT & "," & BTYUNV & "," & BTUNZV & "," & BTYUNB & "," & BTUNZB & "," & BTAPNR & "," & BTPONR & "," & BTYSTT & "," & BTSZTT & "," & BTYENT & "," & BTEZTT & "," & BTIDNR & "," & BTVBME & "," & BTMEKZ
Open Dateiname For Append As #1
Print #1, Eintrag
' Sollwerte aus WinCC TRM_Anteil, TRM_Massenstrom, TRM1, MTRM1..4, TRADD1, MTADD1..4, NAM,Dichte, Niveau , Solltemperatur, NAADD1, NAADD2,MNAM, MNAADD1, MNAADD2
Close #1
End Sub
nun das problem, win cc kennt weder den befehl dim ... as string (anweisungsende erforderlich?!) noch die open funktion...kann da jmd helfen?!
Sub test()
Dim HEUTE As Date
Dim Jetzt As Date
HEUTE = Date
Jetzt = Time
Chargennummer = 1
Einheit = "kg"
MsgBox Dateiname
BTAKKZ = "AS"
BTXUNT = ""
BTAPNR = "G10"
BTMEKZ = Einheit
Print #1, Eintrag
Close #1
End Sub
