Verkaufe SNAP-I/O-Digital Module Bank der Firma OPTO22 bestehend aus folgenden Komponenten:
1 x SNAP-ENET-D64 Ethernet I/O Brain-Digital-only
Beschreibung:
The SNAP-ENET-D64 Ethernet I/O brain is an I/O and communications processor that connects digital devices with Ethernet networks for monitoring, control, and data acquisition. The SNAP-ENET-D64 mounts on a SNAP-D64RS rack with up to 16 SNAP standard digital I/O modules, for a maximum of 64 points of I/O. Note that 32-channel SNAP digital modules cannot be used with this brain
1 x SNAP 64-point Digital-only Rack
Beschreibung:
The SNAP-D64RS holds a SNAP digital-only I/O processor (brain or on-the-rack controller) and 16 four-channel SNAP digital I/O modules, for 64 total points of digital I/O.
7 x SNAP 4-Ch 10-32 VAC/VDC Digital Input Module
Beschreibung:
The SNAP-IDC5 provides four channels of 10-32 Volts DC or AC digital input. Each channel senses the on/off status for DC voltages from sources such as proximity switches, push buttons, or auxiliary contacts. The module has removable top-mounted connectors for easy access to field wiring, as well as channel-specific LEDs for convenient troubleshooting.
5 x SNAP 4-Ch 5-60 VDC Digital Output Modul
Beschreibung:
The SNAP-ODC5SRC provides four channels of 5-60 VDC digital output in a source configuration, each channel switching a separate DC load. The module features a removable top-mounted connector for easy access to field wiring and channel-specific LEDs for troubleshooting.
Die Komponenten sind gebraucht befinden sich jedoch in sehr gutem Zustand und funktionieren einwandfrei. Bitte melden falls interesse besteht. Es existieren auch Bilder von den Komponenten.
Joyou
Beschreibung:
Beschreibung:
Beschreibung:
Beschreibung:
Joyou
