[COLOR=#0000ff][COLOR=#0000ff]Public[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Shared[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Function[/COLOR][/COLOR] SetBit([COLOR=#0000ff][COLOR=#0000ff]ByRef[/COLOR][/COLOR] Byt [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR], [COLOR=#0000ff][COLOR=#0000ff]ByVal[/COLOR][/COLOR] Bit [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Integer[/COLOR][/COLOR], [COLOR=#0000ff][COLOR=#0000ff]ByVal[/COLOR][/COLOR] State [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Boolean[/COLOR][/COLOR]) [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Boolean[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Try[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]If[/COLOR][/COLOR] Bit > 7 [COLOR=#0000ff][COLOR=#0000ff]Then[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Return[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]False[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Dim[/COLOR][/COLOR] OrMask [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR] = [COLOR=#0000ff][COLOR=#0000ff]CType[/COLOR][/COLOR](&H1 << Bit, [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR])
[COLOR=#0000ff][COLOR=#0000ff]Dim[/COLOR][/COLOR] AndMask [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR] = [COLOR=#0000ff][COLOR=#0000ff]CType[/COLOR][/COLOR](&HFF [COLOR=#0000ff][COLOR=#0000ff]Xor[/COLOR][/COLOR] OrMask, [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR])
[COLOR=#0000ff][COLOR=#0000ff]If[/COLOR][/COLOR] State = [COLOR=#0000ff][COLOR=#0000ff]True[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Then[/COLOR]
[/COLOR]Byt = Byt [COLOR=#0000ff][COLOR=#0000ff]Or[/COLOR][/COLOR] OrMask
[COLOR=#0000ff][COLOR=#0000ff]Return[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]True[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Else[/COLOR]
[/COLOR]Byt = Byt [COLOR=#0000ff][COLOR=#0000ff]And[/COLOR][/COLOR] AndMask
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]End[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]If[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Catch[/COLOR][/COLOR] ex [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] Exception
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]End[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Try[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]End[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Function[/COLOR][/COLOR]
[COLOR=#0000ff]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Public[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Shared[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Function[/COLOR][/COLOR] GetBit([COLOR=#0000ff][COLOR=#0000ff]ByRef[/COLOR][/COLOR] Byt [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR], [COLOR=#0000ff][COLOR=#0000ff]ByVal[/COLOR][/COLOR] Bit [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Integer[/COLOR][/COLOR]) [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Boolean[/COLOR]
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]Dim[/COLOR][/COLOR] AndMask [COLOR=#0000ff][COLOR=#0000ff]As[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR] = [COLOR=#0000ff][COLOR=#0000ff]CType[/COLOR][/COLOR](&H1 << Bit, [COLOR=#0000ff][COLOR=#0000ff]Byte[/COLOR][/COLOR])
[COLOR=#0000ff][COLOR=#0000ff]Return[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]CType[/COLOR][/COLOR](((Byt [COLOR=#0000ff][COLOR=#0000ff]And[/COLOR][/COLOR] AndMask) >> Bit) [COLOR=#0000ff][COLOR=#0000ff]And[/COLOR][/COLOR] &H1, [COLOR=#0000ff][COLOR=#0000ff]Boolean[/COLOR][/COLOR])
[/COLOR][COLOR=#0000ff][COLOR=#0000ff]End[/COLOR][/COLOR] [COLOR=#0000ff][COLOR=#0000ff]Class[/COLOR]
[/COLOR]
