Dear,
I have two PCs (virtual machines) connected in LAN.
First computer has installed PLC-Sim, with LAN IP: 192.168.0.11 -> Network IP in NetToPlcSim
In S7 I configured Industrial Ethernet between PLC (IP: 192.168.0.1) and PC Station(IP: 192.168.0.2) -> PlcSim IP in NetToPLCSim
Second PC (intended for PC Station) has LAN IP: 192.168.0.2
Here, I can turn on Siemens OPC Server (and client) properly, without any problems (but currently I will not consider this case, because I didn't succeed much easier task)
Namely, I can ping PC1 from PC2 and vice versa (is it possible PLC pinging via NetToPlcSim due to S7 connection?).
But, when I put PlcSim in Run mode, and after clicking "Start all" in NetToPlcSim,
I noticed that communication doesn't work with PC2.
When I type "netstat" (on both side) I see that connection is not established (via NetToPlcSim),
but when I type manually "telnet ip 102" (on both side) then I can see (via netstat) that connection is established.
Why communication is not established via NetToPlcSim? Could you help me with some advice?
P.C. Sorry, I don't know the Germany very well, but I read a lot of posts in this topic!
Kind regards
