habe gerade erfolgreich drei Fanuc SPSen "down geloadet".
Kenne die SPS sonst nicht.
Die Meldung in der Diagnose ist:
CPU Diagnostic
PLC Fault Table (Displaying 9 of 9 faults, 0 Overflowed)
Loc (rack.slot) Fault Description Date/Time
0.0 Failed battery signal 01-01-98 16:52:25
0.0 Failed battery signal 01-01-98 16:47:24
0.0 Failed battery signal 01-01-98 16:46:46
0.0 Failed battery signal 01-01-98 16:45:31
0.0 Failed battery signal 01-01-98 16:38:13
0.0 Failed battery signal 01-01-98 16:38:02
0.0 Failed battery signal 01-01-98 00:00:02
0.0 Failed battery signal 12-30-1899 00:00:00
0.0 PLC CPU hardware failure 12-30-1899 00:00:00
Error Code Group Action Task Num
2 13 3:Fatal 0
Fault Extra Data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IO Diagnostic
I/O Fault Table (Displaying 4 of 4 faults, 0 Overflowed)
Loc CIRC No. Ref. Address Fault Category Fault Type Date/Time
0.1 n/a %I 00017 Addition of exp unit Addition of exp unit 01-01-98 16:47:26
0.1 n/a %I 00017 Loss of exp unit Loss of exp unit 01-01-98 16:47:24
0.1 n/a %I 00017 Loss of exp unit Loss of exp unit 01-01-98 16:46:46
0.1 n/a %I 00017 Addition of exp unit Addition of exp unit 01-01-98 00:00:01
liest sich als "KISTE HINÜBER".
Kann mir bitte Jemand bewerten, ob Kiste hinüber - tauschen - richtig ist, oder ob es noch sinnvoll ist erste Hilfe zu leisten.
Gruss
Kurt
CPU Diagnostic
2 13 3:Fatal 0
IO Diagnostic
Gruss
Kurt
