IB IL TEMP 4/8 RTD-PAC PCP config?
emilg
Hello
I have a ILC131, with 2x IB IL TEMP 4/8 RTD-PAC. I want to use the PCP channel configuration instead of FB in the Program.
But how can i enable the PCP configuration?
Where will i get the Processdata from the module?
-Emil
Hello Emil,
I attached the data sheet where the PCP Objects are described.
You can find all the information about PCP on page 19.
Note: even without PCP you can use the Processdata in the ProcessDataAssignment without the functionblocks.
(that way you dont have to access the module via PCP and can write your own Functionblock or access the modules data in a program.)
kind regards,
O. Warneke
