Koordinaten ermitteln -> http Search
ich hab da mal was "provisorisches" hingebastelt:
TYPE
    JsonPlace :     STRUCT
        place_id : UDINT;
        licence : STRING[255];
        osm_type : STRING[20];
        osm_id : UDINT;
        lat : REAL;
        lon : REAL;
        class : STRING[20];
        type : STRING[20];
        place_rank : INT;
        importance : REAL;
        addresstype : STRING[20];
        display_name : STRING[255];
        boundingbox : ARRAY[1..4]OF REAL;
    END_STRUCT;
END_TYPE
VAR
    Client : httpsClient;
    PlaceData : JsonPlace;
    jsonString : STRING[1024];
    posStart : INT;
    posEnd : INT;
    RequestHeader : httpRequestHeader_t;
    tempStr : STRING[255];
    restStr : STRING[1024];
    Strasse : STRING[128];
END_VAR
PROGRAM _INIT
   RequestHeader.protocol := 'HTTP/1.1';
   RequestHeader.contentType := 'text/html';
   RequestHeader.contentLength := 0;
   RequestHeader.connection := 'Close';
   RequestHeader.keepAlive := 'timeout=5, max=100';
   RequestHeader.userLine[0].name := 'User-agent';
   RequestHeader.userLine[0].value := 'BuR Client';
   RequestHeader.host := 'localhost';
   Client.method             := httpMETHOD_GET;
   Client.option             := httpOPTION_HTTP_11;
   Client.pHost := ADR('nominatim.openstreetmap.org');
   Client.pUri := ADR('search?q=Schanzenstrasse%2090,8500%20Hamburg&format=json&limit=1');
   Client.pRequestHeader := ADR(RequestHeader);
   Client.hostPort         := 443;
   Client.pResponseData     := ADR(jsonString);
   Client.responseDataSize := SIZEOF(jsonString);
END_PROGRAM
PROGRAM _CYCLIC
    Client(enable := TRUE); (* Call httpClient() *)
    IF Client.status <> 0 THEN
      Client.send := FALSE;
    END_IF
    IF Client.httpStatus = 200 THEN
         // place_id
        posStart := FIND(IN1 := jsonString, IN2 := '"place_id":') + LEN('"place_id":');
        restStr := MID(jsonString, LEN(jsonString), posStart);
        posEnd := FIND(IN1 := restStr, IN2 := ',');
        tempStr := MID(restStr, posEnd - 1, 1);
        PlaceData.place_id := STRING_TO_UDINT(tempStr);
        // licence
        posStart := FIND(IN1 := jsonString, IN2 := '"licence":"') + LEN('"licence":"');
        posEnd := FIND(IN1 := restStr, IN2 := '"');
        PlaceData.licence := MID(restStr, posEnd - 1, 1);
        // osm_type
        posStart := FIND(IN1 := jsonString, IN2 := '"osm_type":"') + LEN('"osm_type":"');
        PlaceData.osm_type := MID(restStr, posEnd - 1, 1);
        // osm_id
        posStart := FIND(IN1 := jsonString, IN2 := '"osm_id":') + LEN('"osm_id":');
        PlaceData.osm_id := STRING_TO_UDINT(tempStr);
        // lat
        posStart := FIND(IN1 := jsonString, IN2 := '"lat":"') + LEN('"lat":"');
        PlaceData.lat := STRING_TO_REAL(tempStr);
        // lon
        posStart := FIND(IN1 := jsonString, IN2 := '"lon":"') + LEN('"lon":"');
        PlaceData.lon := STRING_TO_REAL(tempStr);
        // class
        posStart := FIND(IN1 := jsonString, IN2 := '"class":"') + LEN('"class":"');
        PlaceData.class := MID(restStr, posEnd - 1, 1);
        // type
        posStart := FIND(IN1 := jsonString, IN2 := '"type":"') + LEN('"type":"');
        PlaceData.type := MID(restStr, posEnd - 1, 1);
        // place_rank
        posStart := FIND(IN1 := jsonString, IN2 := '"place_rank":') + LEN('"place_rank":');
        PlaceData.place_rank := STRING_TO_INT(tempStr);
        // importance
        posStart := FIND(IN1 := jsonString, IN2 := '"importance":') + LEN('"importance":');
        PlaceData.importance := STRING_TO_REAL(tempStr);
        // addresstype
        posStart := FIND(IN1 := jsonString, IN2 := '"addresstype":"') + LEN('"addresstype":"');
        PlaceData.addresstype := MID(restStr, posEnd - 1, 1);
        // name
        posStart := FIND(IN1 := jsonString, IN2 := '"name":"') + LEN('"name":"');
        PlaceData.name := MID(restStr, posEnd - 1, 1);
        // display_name
        posStart := FIND(IN1 := jsonString, IN2 := '"display_name":"') + LEN('"display_name":"');
        PlaceData.display_name := MID(restStr, posEnd - 1, 1);
        // boundingbox[1] bis [4]
        posStart := FIND(IN1 := jsonString, IN2 := '"boundingbox":["') + LEN('"boundingbox":["');
        // boundingbox[1]
        PlaceData.boundingbox[1] := STRING_TO_REAL(tempStr);
        // boundingbox[2]
        restStr := MID(restStr, LEN(restStr), posEnd + 2);
        PlaceData.boundingbox[2] := STRING_TO_REAL(tempStr);
        // boundingbox[3]
        PlaceData.boundingbox[3] := STRING_TO_REAL(tempStr);
        // boundingbox[4]
        PlaceData.boundingbox[4] := STRING_TO_REAL(tempStr);
    ELSE
        // GGF. FEHLERBEHANDLUNG
    END_IF
END_PROGRAM
PROGRAM _EXIT
    (* Release Client instance *)
    Client(enable := 0, send := 0);
END_PROGRAM
Es fehler natürlich Fehlerbehandlungen, Behandlung von HTML-Sonderzeichen etc. und das Parsen müsste als Funktion gemacht werden. Also nur mal so für die ersten Schritte gut. Ausgeführt wird das, wenn du z.B. im Watchfenster den Parameter "send" auf TRUE setzt. Beachte auch, das ein Polling dieser Webseite immer > 1 Sekunde ist, sonst wirst du eventuell gesperrt :)
Viel Erfolg damit...
Hier noch mal das ganze als komplettes Demoprogramm mit der eigenen Bibliothek "GeoLib".
Für Ort kannst du den Ortsnamen, oder die Postleitzahl verwenden. Da du die Suche auf EIN Ergebnis einschränkst, empfehle ich die Angabe der Postleitzahl.
Fehlerbehandlungen und Behandlung von HTML-Sonderzeichen sind noch nicht implementiert.
Ich hab auch mal ne Frage, wozu braucht man sowas in einer Steuerung ?
