Libnodave and Visual Studio 2008
Rick
Wenn the programm is calling this function, it hangs on the
ph = openSocket(port, Peer$)
Port = 102 (as long)
Peer = 192.168.0.1 (as string)
i use
Microsoft studio 2008
Vista 64 Bits
write in visual basic
Microsoft Visual Studio Solution (.sln)
file included in the *.rar
Thank you.....
' End of interface declarations and helper functions.
PublicFunction initialize(ByRef ph AsLong, ByRef di AsLong, ByRef dc AsLong)
Dim res AsLong
Dim Peer AsString
Dim port AsLong
Dim MpiPpi AsLong
Dim Rack AsLong
Dim Slot AsLong
ph = 0
di = 0
dc = 0
REM uncomment the daveSetDebug... line, save your sheet
REM run excel from dos box with: excel yoursheet >debugout.txt
REM send me the file debugout.txt if you have trouble.
REM call daveSetDebug(daveDebugAll)
initialize = -1
Peer$ = Form1.TextBox1.Text
port = 102
'Form1.Label3.Text = openSocket(port, Peer$)
ph = openSocket(port, Peer$) ' for ISO over TCP
If (ph > 0) Then
di = daveNewInterface(ph, ph, "IF1", 0, daveProtoISOTCP, daveSpeed187k)
res = daveInitAdapter(di)
If res = 0 Then
' with ISO over TCP, set correct values for rack and slot of the CPU
Rack = Form1.TextBox2.Text
Slot = Form1.TextBox3.Text
dc = daveNewConnection(di, MpiPpi, Rack, Slot)
res = daveConnectPLC(dc)
If res = 0 Then
initialize = 0
EndIf
EndIf
EndIf
EndFunction
Hallo Rick,
i think, this is the initialisation routine for LibNoDave with Excel, but i am not sure. I recommand the following routine, which is tested with VB2005:
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Option[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Explicit[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]On[/COLOR][/SIZE]
[SIZE=1][COLOR=#0000ff]Option[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Strict[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Off[/COLOR][/SIZE][/COLOR][/SIZE]
[SIZE=1][COLOR=#0000ff]Public[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Class[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] Form1[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] localMPI [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Integer[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] = 1, plcMPI [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Integer[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] = 2[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] fds [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] libnodave.daveOSserialType[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] di [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] libnodave.daveInterface[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] dc [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] libnodave.daveConnection[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] res [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Integer[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] = 1[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] livebit [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Boolean[/COLOR][/SIZE][/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Public[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Sub[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] ISO_TCP()[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] IP [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]String[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1]IP = cbxIP.Text[/SIZE]
[SIZE=1]fds.rfd = libnodave.openSocket(102, IP) [/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000]'Portstatus - lesen[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1]fds.wfd = fds.rfd [/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000]'Portstatus schreiben = Portstatus - lesen[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1]di = [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]New[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] libnodave.daveInterface(fds, [/SIZE][SIZE=1][COLOR=#800000][SIZE=1][COLOR=#800000]"Mein Interface"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1], localMPI, _[/SIZE]
[SIZE=1]libnodave.daveProtoISOTCP, libnodave.daveSpeed187k)[/SIZE]
[SIZE=1]di.setTimeout(1000000)[/SIZE]
[SIZE=1]res = di.initAdapter[/SIZE]
[SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] res = 0 [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Then[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000]'initAdapter OK[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1][COLOR=#008000][SIZE=1][COLOR=#008000]' Rack und Slot spielen keine Rolle bei diesem Protokoll[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1]dc = [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]New[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1] libnodave.daveConnection(di, plcMPI, 0, 2)[/SIZE]
[SIZE=1]res = dc.connectPLC()[/SIZE]
[SIZE=1]livebit = [/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]True[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1]...[/SIZE]
[SIZE=1]...[/SIZE][SIZE=1][COLOR=#0000ff]
[/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]If[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=1][COLOR=#0000ff][SIZE=1][COLOR=#0000ff]Sub[/COLOR][/SIZE]
[/COLOR][/SIZE]
Good Luck
Earny
IdOn`t know i think its Any CPU.
But i switched to Visual Basic Express.....
I know that on my Laptop 64 Bits they file project was not working.
that means wenn is call a Libnodave function it crasehes.
On my 32 Bit machine the projectworked oke.
Gr. Rick
When you compile an application as Any CPU, it will run on a 64 bit machine in 64 bit mode.
libnodave is a 32 bit dll, so you have to compile your application as x86.
It's not allowed to mix various assemblies/dlls in different machine modes.
