bei der Installation der Software "TIA v14 SP1 Upd2" bekomme ich die Meldung
Nach dem Neustart bekomme ich immer noch das Gleiche. Und weiter so...
Auch passiert das Gleiche wenn ich "WinCC flexible 2008 Upd8" installiere.
Was kann ich damit machen, dass neue Update installieren kann?
Danke für die Hilfe.
Daten aus log-file (TIA)
________________________
15:21:00| | | *** SIA-Starter ***
15:21:00| | |Start at : 2017-08-29; 15:21:00
15:21:00| | |Commandline_org:
15:21:00| | |Commandline_int:
15:21:00| | |Version : 401.0.104.2
15:21:00| | |Date : 2017-02-20
15:21:00| | |BootTime : 0d 0h 6m 41s
15:21:00| | |OS ver : 6.1 SP:1.0 Service Pack 1 BN:7601 PType:1
15:21:00| | |OS arc : 64
15:21:00| | |OS language : 1031
15:21:00| | |PC name : PC051
15:21:00| | |RAM API : 16256
15:21:00| | |HDD c: : 19363 MB
15:21:00| |CheckBundlePath |Start of checking access to bundle path...
15:21:00| |CheckBundlePath | Bundlepath not found in command line arguments
15:21:00| |CheckBundlePath |End of checking access to bundle path...
15:21:00| |ADSSetAllPath |Start Initialize common pathes...
15:21:00| |ADSSetAllPath | Temp path: C:\Users\administrator.INTERN\AppData\Local\Temp\
15:21:00| |ADSSetAllPath | Starter path: C:\Users\administrator.INTERN\AppData\Local\Temp\SIMATIC TIAP V14.0 SP1 Upd2\Start.exe
15:21:00| |ADSSetAllPath | Current dir: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\
15:21:00| |ADSSetAllPath | Current Commondir: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant
15:21:00| |ADSSetAllPath |look for sia.cfg path: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\sia.cfg
15:21:00| |ADSSetAllPath |look for: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2.ini return 1| errorcode : 2
15:21:00| |ADSSetAllPath |look for: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA.ini return 0| errorcode : 183
15:21:00| |ADSSetAllPath |sia.cfg not found| Path: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\
15:21:00| |ADSSetAllPath |CurrentPath: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\
15:21:00| |ADSSetAllPath |Current ResourcesPath: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\
15:21:00| |ADSSetAllPath |Search SIA2.ini at: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2.ini
15:21:00| |ADSSetAllPath |Get CopyFile from C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2.ini returns Sia.Engine.dll;Setup.Core.dll;Sia2.exe
15:21:00| |ADSSetAllPath |SIA2.ini found| use Sia2.ini from: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2.ini
15:21:00| |CLanguage::Init |BundleTitleShort: Siemens TIA Portal V14.0 SP1 Upd2
15:21:00| |CLanguage::Init |BundleTitle: Siemens TIA Portal V14.0 SP1 Upd2
15:21:00| |CLanguage::Init |Copyright: © Siemens AG| 2008 15:21:00| |CLanguage::Init |CheckAdmin: 1
15:21:00| |CLanguage::Init |Read SIA.ini| STARTER section: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2.ini
15:21:00| |CLanguage::Init |Search SIA2_xxx.ulf files: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\SIA2*.ulf
15:21:00| |CLanguage::Init |Found some SIA2_xxx.ulf files| read
15:21:00| |SetImage |SIA Spash image found at: C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\PictureSplash.png
15:21:00| |GetLangString |LangKey: SetupCaption
15:21:00| |GetLangString |return LangKey from SIA.ini: SetupCaption| Result: Siemens TIA Portal V14.0 SP1 Upd2 - Setup
15:21:00| |GetLangString |LangKey: Copyright
15:21:00| |GetLangString |return LangKey from ULF: Copyright| Result: © Siemens AG| 2008 15:21:00| |GetLangString |LangKey: CheckPrerequisites
15:21:00| |GetLangString |return LangKey: CheckPrerequisites| Result: Überprüfe Voraussetzungen...
15:21:00| |CSiaStarterApp::InitInstance |show splash
15:21:00| | |SIA icon found at C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\Resources\ARP.ico| load ...
15:21:00| |CatchSIASplash 0 |Start looking for SIA Splash
15:21:01| |GetLangString |LangKey: CheckPrerequisites
15:21:01| |GetLangString |return LangKey: CheckPrerequisites| Result: Überprüfe Voraussetzungen...
15:21:01| | |SetProgress: Überprüfe Voraussetzungen...
15:21:01| |IsAnotherInstanceRunning |Mutex=280| value=0
15:21:01| |IsAnotherInstanceRunning |Mutex=284| value=0
15:21:01| |CheckFreeDiskSpace |Check free bytes=5242880 on path=C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant
15:21:01| |CheckFreeDiskSpace |FreeBytesToCaller=20303540224
15:21:01| |CheckFreeDiskSpace |TotalBytes=255087079424
15:21:01| |CheckFreeDiskSpace |FreeBytes=20303540224
15:21:01| |CheckFreeDiskSpace |FreeBytesToCaller=20303540224 >= requested bytes=5242880
15:21:01| |CheckFreeDiskSpace |Test returns=true
15:21:01| |UpdateSIA |Start of updating local copy SIA...
15:21:01| |UpdateSIA | Version of bundle SIA: 401.0.104.2
15:21:01| |UpdateSIA | Version of local SIA: 401.0.104.2
15:21:01| |UpdateSIA | Local SIA is >= bundle SIA. Skip updating.
15:21:01| |UpdateSIA | Path with SIA2.exe is set to "C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\401"
15:21:01| |UpdateSIA |End of updating local copy SIA...
15:21:01| |StartSIA | Silent mode from sia.ini = NO
15:21:01| |StartSIA | Reboot mode from sia.ini = YES
15:21:01| |GetLangString |LangKey: FileNotFound
15:21:01| |GetLangString |return LangKey: FileNotFound| Result: Datei %s wurde nicht gefunden !
15:21:01| |GetLangString |LangKey: MinResolution
15:21:01| |GetLangString |return LangKey: MinResolution| Result: Das Setup benötigt die minimale Bildschirmauflösung %dx%d! Bitte das Setup mit dieser oder höherer Auflösung erneut starten.
15:21:01| |GetLangString |LangKey: RebootMessage
15:21:01| |GetLangString |return LangKey: RebootMessage| Result: Sie müssen Ihren Rechner neu starten| bevor Sie das Setup durchführen können. Wollen Sie den Neustart sofort durchführen?
15:21:01| |GetLangString |LangKey: InstallErrorMessage
15:21:01| |GetLangString |return LangKey: InstallErrorMessage| Result: Bei der Installation von %s ist ein Fehler aufgetreten.
15:21:01| |StartSIA |Check for ReservedPathLength (at least 50)
15:21:01| |StartSIA |ReservedPathLength: 95
15:21:01| |StartSIA |Check for x64Allowed
15:21:01| |StartSIA |Check for admin rights
15:21:01| |LaunchAppGetExitCodeSchell |Start function LaunchAppGetExitCodeSchell...
15:21:01| |LaunchAppGetExitCodeSchell |TaskName=
15:21:01| |LaunchAppGetExitCodeSchell |TaskCommand=1
15:21:01| |LaunchAppGetExitCodeSchell |ExeToStartPath=
15:21:01| |LaunchAppGetExitCodeSchell |ExeToStartArgs=
15:21:01| |LaunchAppGetExitCodeSchell |UserContext(/RU)=
15:21:01| |LaunchAppGetExitCodeSchell |bWait=1
15:21:01| |LaunchAppGetExitCodeSchell |bSilent=0
15:21:01| |LaunchAppGetExitCodeSchell |Set default TaskName=ContinueAfterReboot_SIAStarter
15:21:01| |LaunchAppGetExitCodeSchell |SetTaskParams=/delete /f /tn ContinueAfterReboot_SIAStarter
15:21:01| |LaunchAppGetExitCodeSchell |Try to start schtasks.exe with param /delete /f /tn ContinueAfterReboot_SIAStarter
15:21:01| |LaunchAppGetExitCodeSchell |bRetShell=1
15:21:01| |LaunchAppGetExitCodeSchell |ShellExecuteEx successfully starts file=schtasks.exe
15:21:01| |LaunchAppGetExitCodeSchell |Wait for exit started process...
15:21:01| |LaunchAppGetExitCodeSchell |Started process exits with errocode=0
15:21:01| |LaunchAppGetExitCodeSchell |Return from function with errorcode=0
15:21:01| |StartSIA |Check for screen resolution
15:21:01| |StartSIA |DisplaySize requested: 800x480
15:21:01| |StartSIA |DisplaySize found: 1920x1080
15:21:01| |StartSIA |Not Silent mode| test screen resolution
15:21:01| |StartSIA |Check for installed IE
15:21:01| |StartSIA |Found IE: 99600
15:21:01| |StartSIA |Check for MSI version
15:21:01| |StartSIA |MsiVersion found 5.0.7601.23593
15:21:01| |StartSIA |Check for installed .Net versions
15:21:01| |StartSIA |Detected installed .NET versions:
15:21:01| |StartSIA | 2.0.50727.8762
15:21:01| |StartSIA | 3.0.4506.5464
15:21:01| |StartSIA | 3.5.30729.5420
15:21:01| |StartSIA | 4.7.2102.0
15:21:01| |StartSIA | 4.7.2053.0
15:21:01| |StartSIA |.NET is present. SIA can start.
15:21:01| |StartSIA |Check for PendingFileRenameOperations
15:21:01| |CheckPendingFile |Test PendingFileRenameOperations
15:21:01| |CheckPendingFile |Found PendingFileRenameOperations:
15:21:01| |StartSIA |PendingFileRenameOperations Reboot is needed
15:21:01| |GetLangString |LangKey: SetupCaption
15:21:01| |GetLangString |return LangKey from SIA.ini: SetupCaption| Result: Siemens TIA Portal V14.0 SP1 Upd2 - Setup
15:21:01| |GetLangString |LangKey: ButtonReadme
15:21:01| |GetLangString |return LangKey: ButtonReadme| Result: &Liesmich-Datei anzeigen
15:21:01| |GetLangString |LangKey: ButtonYes
15:21:01| |GetLangString |return LangKey: ButtonYes| Result: &Ja
15:21:01| |GetLangString |LangKey: ButtonNo
15:21:01| |GetLangString |return LangKey: ButtonNo| Result: &Nein
15:21:05| |LaunchAppExt |Start function LaunchAppExt...
15:21:05| |LaunchAppExt |szApp=c:\windows\explorer.exe
15:21:05| |LaunchAppExt |szCmdLine=/c C:\USERS\ADMINISTRATOR.INTERN\APPDATA\LOCAL\TEMP\SIMATIC TIAP V14.0 SP1 UPD2\InstData\..\Documents\Readme\Deutsch\ReadMeTIAPUPDATEdeDE.chm
15:21:05| |LaunchAppExt |szCurrDir=(null)
15:21:05| |LaunchAppExt |bWait=0
15:21:05| |LaunchAppExt |bSilent=0
15:21:05| |LaunchAppExt |Do not wait for started process due WAIT=false
15:21:05| |LaunchAppExt |Return from function with errorcode=0
15:21:05| |LaunchAppExt |Return from LaunchAppExt with exitcode=0
15:21:15| |GetLangString |LangKey: RebootHint
15:21:15| |GetLangString |return LangKey: RebootHint| Result: Ohne einen vorherigen Neustart (Reboot) kann leider nicht fortgefahren werden. Bitte führen Sie diesen Neustart selbst durch.
15:21:16| |StartSIA |PendingFileRenameOperations Reboot: select NO
15:21:16| | |stop spash thread
15:21:17| | | *** SIA-Starter ***
15:21:17| | |End at : 2017-08-29; 15:21:17
15:21:17| | |
15:21:17| | |
15:21:17| | |
15:21:17| | |
