und das projekt ist mit V13.0 SP1 neu erstellt?
Irgendwie stehen bei mir in der Registry etwas mehr drinne:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\SINEC\LogDevices\PLCSIM S7-1200/S7-1500(TCP/IP)]
"LOG_DEV_ACTIVE"="YES"
"LOC_SUBNET_NB"="0"
"L4DRIVER_SIM"="Siemens.Simatic.SoftNet32.dll"
"L4_TIMEOUT"="181"
"L4_SrSync"="1"
"L4_PROTOCOL"="TCPIP"
"L4_KeepAliveOn"="1"
"L4_FastAck"="0"
"L4_ExplAck"="0"
"KeepAliveTime"="720000"
"HardwareID"="*SIEA086"
"DeviceID"="*SIEA086"
"CP_TYPE"="H1"
"Unit"="siemens.simatic.softnet32.dll"
"BoardMap"="1"
"LogdeviceName"="PLCSIM S7-1200/S7-1500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\SINEC\LogDevices\PLCSIM S7-1200/S7-1500(TCP/IP)\NDi]
"is default"="YES"
"PGSP_Register#"="0"
"hidden"="NO"
"enable_delete"="NO"
"DisableCopy"="YES"
"DescTextK"="Ϊ PLCSIM Ö´ÐÐ TCP-IP ͨÐÅ·ÂÕæµÄÐéÄâÉ豸·ÖÅä²ÎÊý¡£"
"DescTextJ"="PLCSIMによってシミュレートされたバーチャルダミーデバイスに、TCP-IP用パラメータを割り当てています。"
"DescTextE"="Assegnazione dei parametri per un dispositivo dummy virtuale simulato da PLCSIM per TCP-IP."
"DescTextD"="Asignar parámetros a un dispositivo dummy virtual simulado por PLCSIM para TCP-IP."
"DescTextC"="Affectation de paramètres pour une unité factice virtuelle simulée par PLCSIM pour TCP-IP."
"DescTextB"="Assigning Parameters for a virtual dummy device which is simulated by PLCSIM for TCP-IP."
"DescTextA"="Parametrierung eines virtuellen Gerätes für den Netzwertyp TCP/IP, der von PLCSIM simuliert wird."
"DescText"="Assigning Parameters for a virtual dummy device which is simulated by PLCSIM for TCP-IP."
"DefLogDevice"="PLCSIM S7-1200/S7-1500(TCP/IP)"
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\SINEC\LogDevices\PLCSIM S7-1200/S7-1500(TCP/IP)\SubDevices]
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\SINEC\LogDevices\PLCSIM S7-1200/S7-1500(TCP/IP)\SubDevices\PST]
"L4DRIVER"="S7OTSPSX.DLL"
"LOC_SUBNET_NB"="0"
"L4_TIMEOUT"="181"
"L4_SrSync"="1"
"L4_FastAck"="0"
"L4_ExplAck"="0"
"CP_TYPE"="H1"
"BoardMap"="1"
"is default"="YES"
"hidden"="NO"
"DisableCopy"="YES"
