public void PLCPutBlockFromMC7toPLC(string BlockName, byte[] buffer)
if (AutoConnect && !Connected)
Connect();
if (_dc != null)
lock (_dc)
string tmp = BlockName.ToUpper().Trim().Replace(" ", "");
string block = "";
int nr = 0;
if (tmp.Length > 3 && tmp.Substring(0, 3) == "SDB")
block = tmp.Substring(0, 3);
nr = Int32.Parse(tmp.Substring(3));
else
block = tmp.Substring(0, 2);
nr = Int32.Parse(tmp.Substring(2));
DataTypes.PLCBlockType blk = DataTypes.PLCBlockType.AllBlocks;
switch (block)
case "FC":
blk = DataTypes.PLCBlockType.FC;
break;
case "FB":
blk = DataTypes.PLCBlockType.FB;
break;
case "DB":
blk = DataTypes.PLCBlockType.DB;
break;
case "OB":
blk = DataTypes.PLCBlockType.OB;
break;
case "SDB":
blk = DataTypes.PLCBlockType.SDB;
break;
if (blk == DataTypes.PLCBlockType.AllBlocks || nr < 0)
throw new Exception("Unsupported Block Type!");
int readsize = buffer.Length;
int ret = _dc.putProgramBlock(Helper.GetPLCBlockTypeForBlockList(blk), nr, buffer, ref readsize);
if (ret == 53825)
throw new Exception("PLC is Password Protected, unlock before downloading Blocks!");
else if (ret != 0)
throw new Exception("Fehler Code:"+ret.ToString());
