WinCC WinCC Alternative
mark_00
I have been quite a long a convinced Siemens guy, using their PLCs and visualisation for more than 15 years now.
I have done a lot of small projects like 1 to 2 PLC and than visualisation, mostly for machinery. More and more customers are asking for more functions like web access, production statistics, reporting. I am not able to do it with Siemens due to its limits, so I am looking for alternatives.
I don't want to replace S7 just the visualisation. Are there any options, does it make sense?
Thanx, Mark
[FONT=&quot]Hi Mark,
I have went to same path. Definitely go for a web based solution. I tried the zenon from copadata, it is a nice system with a lot of functions, but they are ridicously expensive! I have done one installation with them and they charge you for anything, in final I have payed much more I would for a Siemens system. Recetnly I have discovered mySCADA, web based SCADA system, nice looking, very fast and everything is in one install package. Can connect nattively to Siemens S7 and to Rocwell as well (tested). I am doing first project with myscada.org, I have run to some smaller issues, all solved very quicky with their tech team. They have been very supportive and did not charge me anything! On the pricing, they are much cheaper than Siemens or copa and charge only for runtime. So far, the best system I have used.
O.
[/FONT]
@Thomas_v2.1 - That is true! But you cannot tell that to the customers :wink:
@oli76 - thank you! I´ll check myscada. :s1:
