<?xml version="1.0"?>
<?xml-stylesheet type="text/xsl" href="asms.xsl"?>
<assignmentsfile filename="recipe.xml" changed="2006-07-03-11:34:23" key="BABE1234">
<valuesfile filename="format.xml">
<!-- Overview -->
<!-- MACHINE NO. -->
<!-- PAGE FORMAT -->
<!-- PAGE MECHANICAL SETTINGS -->
<section name="MACHINE NAME">
<assign name="Machine number">
<plc_var>sMachineName</plc_var>
<var_default>"form"</var_default>
</assign>
</section>
<!-- PAGE Format -->
<section name="FORMAT">
<assign name="Format name">
<plc_var>sDirFormat</plc_var>
</assign>
</section>
<section name="MECHANICAL SETTINGS">
<assign name="Example setting 1">
<plc_var>fSetting1</plc_var>
<var_default>0</var_default>
</assign>
<assign name="Example setting 2">
</assign>
</section>
</valuesfile>
</assignmentsfile>
TYPE
Rezeptspeicher : STRUCT
Daten : ARRAY[0..99]OF Rezept;
END_STRUCT;
Rezept : STRUCT
Parameter_1 : USINT := 0;
Parameter_2 : DWORD := 0;
Parameter_3 : REAL := 0.0;
Parameter_4 : BYTE := 0;
END_STRUCT;
END_TYPE
VAR
Rezeptdaten : Rezeptspeicher;
Aktuelles_Rezept : Rezept;
END_VAR
