Converting a Codesys project from 32bit to 64bit
Akash
Hi everyone,
I have a codesys project which contains pointers, memory block functions and a lot of cross references. The project was earlier developed for 32bit systems and now my task is to convert it for 64 bit system. What are the things i should consider before starting my work and is there any predefined function in codesys which can help me with the task ?
ps- I tried searching in codesys help page but it has very limited information.
Depends on what is inside the project ;-) It uses ADR and SIZEOF - don't worry. Change the target will do the job.
It uses hardcoded pointer arithmetic --> run. Or: Use ADR SIZEOF and so on...
