Hello,
Ich bin ein Belgier und meine Deutsch ist eine Katastrofe.
Hopefully my englisch is a little better. Now the problem
I have an MRTC module attached on the PLC. For a year ago I bought this module and programmed the real time with
the SET_RTC_DT and the GET_RTC_DT instruction. So far so good until a year later I have to change the program. I even don't know of i missed up
the real time clock but for the moment I have a difference from about 1h10m with the time from my pc. The clock is working because she is counting the time
but with the difference.
Is it possible that i have to remove the MRTC module from the plc or I have to remove the batterie ? Mayby the procedure about the SET_RTC_DT and GET_RTC_DT
id do not correct or the modus (compile, grogram,)..............
Hopefullu somebody can help
Kindly regards
Jean-paul
Kindly regards
Jean-paul
