OP30 C Software?
dodo
Hallo Siemens Gemeinde!
Ich hab eine Anfrag für den Umbau einer alten Maschine aus dem Jahr 1996
Darin eingebaut ist eine S5 mit CPU 944 und ein OP30C.
Weiss jemand, mit welcher Software ich auf diesem OP die Projektierung ändern kann?
Com Text? Coros?
(Projektierungs-Datei konnte ich noch nicht bekommen, deshalb kann ich da keine Info (z.B. aus der Datei-Endung) bekommen)
Für nen schnellen Tip schon mal Danke! :)
The COM GRAPH configuration software for the CP526, CP527, CP528
and OP30 can now be run with the new revision level, A2.32,
on the basis of STEP 5 versions 6.6 and 7.0.
The delivery status has now changed with revision level A2.32.
With immediate effect, COM GRAPH will be supplied only on 3.5"
MS-DOS floppy disks. The installation routine has been
reworked and now allows installation on the basis of
MS-DOS and Windows 95 at the DOS prompt or in Windows
Explorer.
A Product Information brochure is included with the
documentation to describe the current state of the product.
COM GRAPH A2.32 has been tested and released for the PG 720,
PG740 and PG 760.
A reasonably priced update is available.
_Additional Notes_
The following software components, including documentation, are
supplied with the COM GRAPH A2.32 standard package:
Function ! Program Part ! Version
Screen Configuration for ! COM GRAPH ! Version 2.32
CP526, CP527, CP528 and OP30 ! !
EPROM programming tool ! PROM 526 ! Version 4.2
CP526/527 (req'd only for that) ! PROM 527 ! Version 5.1
Tool for converting from ! CONVERT ! Version 2.1
message text to CP format or ! !
to ASCII files and the other way ! !
round ! !
Function block for management ! FB10§§ST.S5D !
of old values for CP/trend window! !
(use in S5-100U (CPU 103),115U ! !
135U, 150U, 155U possible) ! !
Standard library with CP/OP ! COMLIB?.* !
system messages ! !
screens for CP528/ONLINE ! PAR28?.528 !
parameter assignment ! PAR30?.30A !
! PAR30?.30B !
Key to ?: A = German ! !
B = English ! * = 526, 527 !
C = French ! 528, 30A/B!
