I'm using PFC200 and OSCAT Building library to automate my home. I got a question... How are you saving the position of the blind in case of a power failure?
Function BLIND_CONTROL_S has built-in automatic calibration which is needed to know the position of the blind in case of power failure or PLC restart. In such a case, the blind goes up. Is there a way to store the current position so that after the power failure the blind won't go up?
I was trying to add the whole BLIND_CONTROL_S function block to the VAR RETAIN PERSISTENT memory area but this didn't help. I was also trying to store the POS output of the BLIND_CONTROL_S (which is at the same time an input for the POS of the BLIND_INPUT) but this also doesn't stop blinds to go up in case of power failure.
Any ideas?
Any ideas?
