SNTP time on ILC131
emilg
Hello
I have 5 ILC131, i want to synchronize to a SNTP server.
How is that possible?
in the manual for ILC150GSM i fund a chapter:
3.3.2 Setting the realtime clock via SNTP
The Simple Network Time Protocol (SNTP) can be used to synchronize the internal system
clock of the Inline Controller with a higher-level control system (e.g., an SNTP server) via an
Ethernet connection.
Use the following CPU_Set_Value firmware service (02CBhex) to synchronize the system
clock. The service activates or deactivates an SNTP client and transfers the required
"IP address of the SNTP server" and "Cycle time of the synchronization" parameters.
But i'm a little scared with the CPU service editor... :)
Is there a complete example?
- Emil
Hello Emil,
there is an existing library called IT_Library. In this library you will find an SNTP FB you could use.
But for the IT_Library you will need a license which you have to order (Applic A license on SD card)
Freundliche Grüße / Best regards
Ulrich Kleinschmidt
