Steckerbelegung AEG Logistat
Gib doch einfach mal "AEG" in die Suchfunktion hier im Forum ein, in den ca. 125 Fundstellen geht es recht häufig um 020, hier (im Beitrag #30) z.B. ist auch eine Kabelbelegung zu finden.
Grüße von HaDi
Kann HaDi nur beipflichten,
Zitat aus Forumbeitrag:
My English is not so good, but if you just want to find out the
Programm on the A020, I tried the following solution for the A020 for use in my private home:
At first you will need a cable from the serial port of your PC to the A020. My personal experience is that your PC should not be faster than 386/25Mhz because of difficulties with modern serial UART-Chips.
25p (PC) / 25p(A020):
1 / 1
2 / 2
3 / 3
4 / 4
5 / 5
7 / 7
OR:
9p (PC) /25p (A020):
Shield(or 5) / 1
3 / 2
2 / 3
7 / 4
8 / 5
5 / 7
If you don´t own a Software like "Dolog AKL" or "A020fup" you may use a normal Terminal-Programm with the following Transmission codes:
1 Startbit
7 Bit per Character
1-Signal Parity even
1 Stopbit
The Baudrate normaly is 9600. (Possible others: 4800,2400,1200,600,300)
You should get message:
FUS: (OR: *FUS
Type in:
HE (Ret)--------->[Hold A020)
M (Ret)--------->[Show memory)
A020 will sent:
Adr:
Type in (for ex.):1 (Ret)
You will see the program line 1
(For example: 1: UE1 or NO if there is no command)
by pressing the Return-Key you accept the term and reach the next program line.
Example:
1 U E1
2 U E2
3 = A1
840 PE (Programm end)
You can edit the program now.
Leave the Program-Editor by typing E(Ret).
IF YOU CHANGED THE PROGRAMM YOU WILL HAVE
TO TYPE IN "PRZE" TO KEEP THESE CHANGES.
DON`T DO SO IF YOU WANT TO KEEP THE OLD
PROGRAMM !!!
Now you can start the A020 by pressing S(Ret).
I hope I was able to help you.
Best regards
TFB (Germany)
Reply
LG Markus
..alten PC verwenden !!
Bitte den Part mit den alten PC :
"..PC should not be faster than 386/25Mhz .." ernst nehmen. Ein 486 ist sicherlich auch kein Problem, aber mit dem Pentium gibt es dann irgendwann Probleme. Du suchst dann wie blöde bei Deinem selbstgebastelten Kabel, dabei ist der PC einfach zu schnell für die A020.
danke für die auskunft
ist es irgendwie möglich das ganze mit einem schnellen pc auch zu lösen?
Meines Wissens nicht. Ich weiß nicht genau, welche Software Du verwendest. Vermutlich AKL. Hier kommt noch hinzu, dass es eigentlich DOS Programme sind. Das ganze funktioniert noch bis WIN98, danach ist Schicht. Also das Programm läuft natürlich auch auf XP. Aber es kommt nie eine vernünftige Verbindung zu stande. -> ..also alter PC mit altem OS
Was möchtest Du eigentlich machen? Ein altes Programm auslesen oder die A020 einer neuen Nutzung zuführen?
Es gibt da ein Programm mit dem du den Rechner langsamer laufen lassen kannst. (meine jetzt unter XP)
Wie es mit den Schnittstellen aussieht weiß ich leider nicht
Google doch mal nach "DOSBox"
Markus
ich möchte bestehende A020 aktualisieren
Software habe ich die AKL Dolog benutzt, im Moment mit 'Win XP und einer DosBox aber leider kommt bisher keine Verbindung zustande
Gruß Karl
Was verstehst Du unter aktualisieren ? Du willst Änderungen an dem bestehendem Programm machen?
Glaube einem alten AEGler, so wird das nie was. Verschenkte Liebesmüh.
Entweder Du besorgst Dir eine aktuelle Hardware und schreibst das Programm eben neu. Die A020 hatte ja eine überschaubare Anzahl an E/As oder Du besorgst Dir ein altes Notebook.
hiho, suche noch die kabelbelegung für die Verbindung zwischen AEG A 020
von 9pol auf 25 pol.
Habe gesucht und zu viele unterschiedliche gefunden, kann da mal bitte einer helfen?
Folgende Belegungen habe ich gefunden, könnte mir da mal bitte einer entwirren?
Shield(or 5) / 1
3 / 2
2 / 3
7 / 4
8 / 5
5 / 7
RS232 AEG 020
Buchse Stecker
Sub-D 9pol Sub-D 24pol
2 ------------------------------------ 2
3 ------------------------------------ 3
5 -------------GND------------------- 1
I----- 8
I----- 5
Gehäuse-------------------------Gehäuse
DTE 1 DTE 2
9pol 25pol (female) 25pol 9pol (female)
5 7 ---GND---------------------GND------- 7 5
2 3 ---RxD--------. ,----------RxD------- 3 2
X
3 2 ---TxD--------' `----------TxD------- 2 3
7 4 ---RTS--------. ,----------RTS------- 4 7
X
8 5 ---CTS--------' `----------CTS------- 5 8
4 20 ---DTR--------. ,----------DTR------- 20 4
X
6 6 ---DSR--o-----' `--o-------DSR------- 6 6
1 8 ---DCD--' `--DCD------- 8 1
