TcHMI - TE2000 Reading a real variable with Text field
BitLord
Hi there,
I am a newbie at Twincat system. I do mostly work with AB. However, I will need to make a project at Twincat, so I am tryin to get used to TE2000.
When I write into a PLC variable and then read it again from TcHMI, it gives me the following output:
Z
But actually the value is correct at PLC:
Z
Does somebody knows a solution for this problem?
PS: TC3 project is in the attachment.
Update:I also added the jpegs in the attachment.
Your help will be much appreciated! Thanks.
  • TcHmiTest.rar
    TcHmiTest.rar
