Hallo SPS Forum:
Wir suchen einen Entwickler für
TFT-Display-Driver-Boards, kann uns wer eine Firmen empfehlen für einen erschwinglichen Preis?
Anvorderung:
· 24V power input
· Raspberry Pi 5 or Raspberry Pi compute module integrated tot he board integriert, the raspi should be exchangeable, therefore suggesting a raspi compute module. GPIO pins should be accessible for future expansion
· A power pin available on the Board. Reason: the raspi should check the power input and if no 24V available, the raspi should shut down. This option will be programmed by us, we need the power pin only.
· Power contact for an external power button or sensor fort turning the display on/off . This is a contact only, we will use a power button with power cable.
· Touch interface to be integraten on this Board, but the USB connector made available to be connected to the Raspberry Pi
· 2x 24V PWM connectors fort he fans
· 1 or 2x18650 Li-Ion cells with charge circuit as well as step-down power for den Raspi
· Esp32 Modul integrated tot he board with usb-c connector, io header and reset button
· Power contact for completely shut down the system inclusively lipo, in case of maintenance. This is a contact only, we will use a power button with power cable .
· Width 270 mm, Height 220 mm, Depth15 mm
Anvorderung:
· 24V power input
