Hi Guys,
my english isn't that good to write down my question, I have no problem reading/understanding german.
I'm trying to get the Database server from beckhoff Running (on a PC not CE)...
I'm using SQL Server Express 2012 and using a altered version of the Stored procedure example ...
To log on to the Database server (with the SQL server management software:
* Server name: L001311B1\SQLEXPRESS
* Authentication: Windows Authentication
so in the beckhoff XML configuration I put down:
* DB Type: MS SQL
* Database Server: L001311B1\SQLEXPRESS
* Database provider: SQLOLEDB
* Tbl Name: tblEventLogging (but I'm not using the table directly as I'm using a storedprocedure)
If I try to run the stored procedure example
*Start the stored procedure "FTTM_PlcToSqlComm"*)
fbDBStoredProcedures(
sNetID := '',
hDBID := 1,
sProcedureName := 'FTTM_PlcToSqlComm',
cbParameterList := SIZEOF(arrParaList),
pParameterList := ADR(arrParaList),
bExecute := TRUE,
tTimeout := t#15s,
bBusy => bBusy,
bError => bErr,
nErrID => nErrid,
sSQLState => stSqlstate);
I always get the error:
* ErrorID: 16#00040001
* sSqlState: 42000
* SqlErrorCode: 16#80040E4D
even if I use my windows credentials in the XML configuration Tool, I get
* sSqlState: 42000
* SqlErrorCode: 16#80040005
I know my windows authentication username & password is correct but either way throws me errors, some of you have experience with the database server
best regards,
Peter
* DB Type: MS SQL
sNetID := '',
hDBID := 1,
bExecute := TRUE,
tTimeout := t#15s,
bBusy => bBusy,
bError => bErr,
nErrID => nErrid,
* sSqlState: 42000
* sSqlState: 42000
best regards,
Peter
