I am gonna build a new house (120m2, 1 floor, 5 rooms) and now wondering what home automation system I will put in it.
I am automation engineer and I have lots of experience using Beckhoff, Siemens and Omron.
Specifications for home automation system:
* Lighting: Dimmable led lights. Control via DALI. Control system must have been able to change scenes according to timetable. Example: at home in the morning.
* Electricity sockets: Controllable via system.
* Away / Home / Vacation / Night modes
* Air ventilation and Heating control: Speed control for air ventilation system. Temperature drop when Vacation mode activated.
* HMI: web HMI or Android app.
Maybe later:
* Alarm system
* Alexa voice control
I have narrowed my options to two:
OPTION 1: WAGO PLC
I choose WAGO over to Beckhoff because WAGO is cheaper and DALI configurator seems simple to use.
Parts:
WAGO PFC100 starter kit + DALI module + DI / DO modules.
Dali power source
All push buttons (24V) wired to PLC.
Electricity sockets are controlled by PLC output via relays.
Pros:
+ Kind of easy to program. I dont have experience to program DALI to codesys but I dont think this is a problem at all.
+ Maybe little bit cheaper solution than KNX.
+ Web HMI easy to program.
+ Buttons / switches are cheap.
+ MQTT support for future add-ons. (Alexa voice command and MQTT sensors)
Cons:
- Wiring. Every cable needs to be connected to PLC. (This can be avoided by using Enocean ??)
- Buttons / switches are not good as KNX buttons / switches.
- Worst-case scenario. Everything is controlled by PLC. What if PLC is broken ??
OPTION 2: KNX
KNX seems to be a popular choice for home automation. I already took that KNX eCampus course to see what kind of system that is.
It seems to be a bit odd and restricted system. If I choose KNX then I need some help for KNX designing and programming.
Parts.
DALI gateway
Relay actuator
KNX power source
Ip interface
What else ??
Pros:
+ Reliable system. Decentralized system.
+ Wiring more simple
+ Better buttons / switches
Cons:
- More expensive?
- No programming experience.
- Visualization?
Has anyone any toughs about these options ??
Do you think that KNX system can be programmed by novice?
Maybe later:
* Alarm system
OPTION 1: WAGO PLC
Parts:
Dali power source
Pros:
Cons:
OPTION 2: KNX
Parts.
DALI gateway
Relay actuator
KNX power source
Ip interface
What else ??
Pros:
Cons:
- More expensive?
- Visualization?
