Bei mir auch, "PLCSIM V18 hat erkannt, dass eine ältere Version von PLCSIM auf Ihrem System installiert ist..."PLCSIM V18 SP1 gibts ja schon.
Wirft bei mir aber Installationsfehler...SIOS
support.industry.siemens.com
bei mir scheints ein Problem mit DotNet6 zu sein...Bei mir auch, "PLCSIM V18 hat erkannt, dass eine ältere Version von PLCSIM auf Ihrem System installiert ist..."
2023.03.09 10:08:41 - Year.Month.Day - Log start
BUNDLE: S7-PLCSIM V18 SP1
SEBU Version: VPLCSIM_V18.00:18.00.01.00_02.24.00.01
OS: Microsoft Windows 10 Enterprise LTSC - , 64-bit, build 17763
COMMANDLINE: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\410\SIA2.exe /starter /bundlepath=D:\InstData
INSTALLDIR: C:\Program Files\Siemens\Automation
SETUPLANGUAGE: 1031
PRODUCTLANGUAGES: 1033
CHANGES: (+)DotNet_Updater;(+)DotNet6Bundle;(+)DotNetRuntime6x86;(o)PLCSIMADV_Driver64;(o)PLCSIMADV_SimRT;(o)S7-PLCSIMADV;(o)PLCSIM_V18
There are NO severe messages before the installation
10:08:41 | BEGIN. Execution started.
10:08:42 | OK RunningProcesses () Complete
10:08:42 | OK InventoryBefore (A) Complete
10:08:42 | OK Citamis (Before) Complete
10:08:43 | OK SecurityControlFeature (ReturnFeatures) Complete
10:08:43 | OK ClassicCompPrepare () Complete
10:08:44 | OK ProductRegistration (Before) Complete
10:08:44 | OK ClassicCompAfterUninstall () Complete
10:08:45 | OK SetupUnit (DotNet_Updater) Complete Foreign AddLocal
10:08:50 |ERROR AdsWorkerForeignExe::GetInstallResult(): - 1638: assuming unknown error, because return value is not in OK-list which is only defined. Please check the corresponding log file for more detailed information
10:08:50 | FAIL! SetupUnit (DotNet6Bundle) Failed Foreign AddLocal
10:08:53 | OK SetupUnit (DotNetRuntime6x86) Complete Foreign AddLocal
10:09:01 | OKRebootAfterAll SetupUnit (PLCSIMADV_Driver64) Complete ClassicComponentReinstall
10:09:08 | OK SetupUnit (PLCSIMADV_SimRT) Complete ClassicComponentReinstall
10:09:14 | OK SetupUnit (S7-PLCSIMADV) Complete PlusMain Reinstall
10:09:54 | OKRebootAfterAll SetupUnit (PLCSIM_V18) Complete PlusMain Reinstall
10:09:54 | OK ClassicCompAfterInstall () Complete
10:09:54 | OK ClassicCompRollback () Complete
10:09:55 | OK HspInstall () Complete
10:09:55 | OK MspInstall () Complete
10:09:57 | OK StartApplAfter (PLCSIMADV::C:\WINDOWS\SYSWOW64\S7EPATSX.EXE-silent-force)Complete
10:09:58 | OK ProductRegistration (After) Complete
10:10:00 | OK SetupIsComplete () Complete
10:10:01 | OK InventoryAfter (Z) Complete
10:10:02 | OK LicenseTransfer (False) Complete
10:10:02 | OK Citamis (After) Complete
10:10:02 | OK SetupSummary () Complete
10:11:40 | OK SetupReport () Complete
10:11:40 | END. Execution completed.
Intermediate ExitCode after execution queue : 1603 - Exit code means: Installation failed (InstallFailure)
Errors: 1
Warnings: 0
Exit installation with global errorcode : 1603 - Exit code means: Installation failed (InstallFailure)
Ich hatte das gleiche Problem. Von Siemens bekam ich dazu folgende Antwort.Bei mir auch, "PLCSIM V18 hat erkannt, dass eine ältere Version von PLCSIM auf Ihrem System installiert ist..."
Ich habe daraufhin PLCSIM V14 deinstalliert. Danach konnte ich dann PLCSIM V18 SP1 installierenVersionen kleiner V15 sind unverträglich mit PLCSIM Advanced, das automatisch mit PLCSIM V18 SP1 mit installiert wird.
Nach der Deinstallation von PLCSIM V14 (SP1), V13 (SPx) und V12 (SPx), kann PLCSIM V18 SP1 wie gewohnt installiert werden.
Die Entwicklung arbeitet hier an einer Lösung.
PLCSIM V18 SP1 Upd1 scheint bei mir jetzt zu gehn...PLCSIM V18 SP1 gibts ja schon.
Hab ich am Dienstag installiert, das Upd1 lässt sich installieren und läuftPLCSIM V18 SP1 Upd1 scheint bei mir jetzt zu gehn...
