Hello,
I would like to ask for help with positioning on sew servo with using MDX61B drive ,
Servo is controling 2 pistons as shown on screen circled in red color , aplication is : After enable ON1 command bit from PLC control word , drive will start pushing pistons forward to a certain position in which will stop, it should just push the wooden board more forward, so after pistons have reached certain position and they stopped then they need to move back to starting position , then aslo plc need to know some status about actual position of encoder , so basically i need to position limit switch at start and limit switch at end with positioning values , and this cycle will repeat.
Any suggestions ? , best with some example how this would be done , as i don´t have experiences with such applications
I was just guessing what would be easier if using IPOS or using modulo positioning , i have tried something in IPOS in past but it was not positioning.
Any help would be appreciated .
