Configure ScopeView from PLC (TwinCAT3)
IMIRZA
Greetings All,
I am working on TwinCAT3 build 4.022.27.
Is there any possibility to configure the ScopeView from the PLC project?
For example, I need to configure the auto-save filename from the PLC project. In my use-case scenario, I have a scope project which should plot similar data for different inputs and I want to save the recorded data for all those different types of inputs.
At the moment, I have a kind of "dirty" solution where I have created multiple scope projects, one for each type of inputs. The best solution would be to parameterize the scope project with auto-save filename.
Secondly, is there a way to activate "Start Recording" button of the scope project out of PLC project? Although I have correctly configured tiggers to actually start data recording, but first I have to manually start the scope project through "Start Recording" button from the toolbar icon.
Thirdly, Is there a scope-project configuration settings which enables the saving of recorded data directly in CSV file? Currently I am calling the external export tool from PLC project with hard-coded filename (this file is generated through auto-save functionality of the scope project).
Thanks in advance for your time.
Regards
Mirza
